Author Topic: NOC = Number Of Copies  (Read 3513 times)
Andrea
« on: July 25, 2011, 12:43:07 PM »
Hi all...
Little challange for you guys...
I've finaly be able to capture the number of copie when printing.
anyone can reproduce this reactor ?
Keep smile...
Matt__W
  • I like my water diluted.
Re: NOC = Number Of Copies
« Reply #1 on: July 25, 2011, 12:59:00 PM »
(define C:NOC ( / )
   (alert "Number of Copies = 2")
:whistle:
Autodesk Expert Elite
Matt__W
« Reply #2 on: July 25, 2011, 01:01:45 PM »
My LSP is rusty, but I'm assuming it has something to do with the NUMBEROFCOPIES property.
Andrea
« Reply #3 on: July 25, 2011, 01:11:37 PM »
Nice Try Matt..  :)
(vla-get-numberofcopies (vla-get-Plot (vla-get-ActiveDocument (vlax-get-acad-object))))always return 1
Keep smile...
Matt__W
« Reply #4 on: July 25, 2011, 01:12:38 PM »
Nice Try Matt..  :)
In that case, I'm sticking with my first response.  ;)
Andrea
« Reply #5 on: July 25, 2011, 01:43:35 PM »
Nice Try Matt..  :)
Well eaven that....there is no "S" on Copie.  :P
Keep smile...
« Reply #7 on: July 25, 2011, 05:01:47 PM »
Looks like an old problem
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/vla-get-NumberofCopies-Not-Getting/td-p/877840
Not the OPs question. Re-read the first post. There was no question of how to do it, Andrea said that he was able to do something and was asking if anyone else can as well (And, the last person who posted in the link you gave asked what Andrea seems to have done).
Andrea,
Can you give us a hint? Is it a variable or registry setting? I would imagine there is a lot of things it could be or where it would be hiding. Right?
« Reply #8 on: July 25, 2011, 05:18:47 PM »
good thing we haz a monitor
Andrea
« Reply #9 on: July 25, 2011, 05:27:01 PM »
I've worked hard on this one..
but like each program, the programmer need to think of what he realy need..
In fact the question is....
do I want to know how many copy I've put on the dialog?
or
do I want to know how many copy was sent on the printer?
than,...maybe that will direct you to another direction.
 :kewl:
Keep smile...
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #10 on: July 25, 2011, 06:21:38 PM »
what a tease :)
Called Kerry in my other life
I live at UTC + 13.00
alanjt
  • Standby for witty remark...
« Reply #11 on: July 26, 2011, 09:12:17 AM »
Dropbox
