Author Topic: Plotting Line Weight issue from different platforms  (Read 4557 times)
Krushert
  • FREE BEER Tomorrow!!
« on: February 28, 2012, 07:42:03 PM »
I run 2011 ACAD ACA and the other three designers run 2011 ACAD Vanilla.  When I plotted from ACA the line weight thickness is twice that of what is plotted from their three ACAD Vanilla seats.  I have ACAD Vanilla and I plotted the sheet and got the same result (and desired) results that they did.
  • Same ACAD File
  • Same CTB File.
  • Same Plotter.
  • Same PLOT Settings
  • Same Lineweight Settings
  • Same Channel
  • Same BAT Time
Similar Computers
I believe it is a issue with ACA.  I have checked and compared the usual settings and found dissimilarities.
Re: Plotting Line Weight issue from different platforms
« Reply #1 on: February 28, 2012, 08:28:51 PM »
Are they perhaps hitting the little toggle that reads: SCALE LINE WEIGHTS?
Also you might be fighting Visual Display Styles
versus
Layer Line Weight
those are not the same animal
Krushert
« Reply #2 on: February 28, 2012, 08:46:44 PM »
We check that and all was the same. But how it scale line weights if the plot is ebing plotted at 1 to 1   :|
versus
Layer Line Weight
Where would I check for that?
« Last Edit: February 28, 2012, 09:14:17 PM by Krushert »
Krushert
« Reply #3 on: February 28, 2012, 09:18:30 PM »
versus
Layer Line Weight
[/quote]
Okay that was a Stupid question.  Both platforms are set for 2d wireframe.  **sigh**
« Reply #4 on: February 28, 2012, 10:00:18 PM »
Check that the same plotter driver is being used for both applications. I once found that the plotter drivers were updated in one version of AutoCAD and it plotted differently despite using the same plottign tables and settings.
Krushert
« Reply #5 on: February 28, 2012, 10:49:04 PM »
By George, I think you've got it!!!!
One driver and dialogs for the same plotter for one version is totally different that the version.  Totally!.
Good night!
Matt__W
  • I like my water diluted.
« Reply #6 on: February 29, 2012, 08:38:34 AM »
You lost me at "ebing".   :?
Autodesk Expert Elite
Krushert
« Reply #7 on: March 02, 2012, 07:36:23 AM »
Freak if I know.  That's what happens after 3.5 days of working to midnight.  But how is that post any different than any other post of mine.  :| :| :wink:
A follow up:  Still waiting for the head honcho on this special KIP plotter software to come around and take a look.  It looks like a reinstall.
« Reply #8 on: March 02, 2012, 10:31:40 AM »
You didn't say it was a KIP ... what model?
Krushert
« Reply #9 on: March 02, 2012, 12:39:05 PM »
KIP 6000 400DPI Series.
Takes up a lot of floor space.  Seems to work pretty sweet.  Everybody is pretty protective of it.
