Code Red => AutoLISP (Vanilla / Visual) => Topic started by: cyclops on March 04, 2017, 02:37:05 PM
The swamp,
I am looking for a LISP routine that will change a group of layers colors by a value of X.
Let say, the layer group *V-UTIL-* has a color value(s) of X, the LISP command will evaluate the color value each layer in the layer group, then bump the layer color value by a constant value (positive or negative).
For example
BEFORE
Layer Color
v-util-strm 11
v-util-sswr 13
v-util-watr 15
AFTER
Layer Color
v-util-strm 13 or 09
v-util-sswr 15 or 11
v-util-watr 17 or 13
Thanks for the help in advance.
CyclOps
Try the following:
(defun c:laycolshift
( / int pat
For your example, you would enter v-util-* and plus or minus 2 at each respective prompt.
Lee,
I will try this out.
CyclOps
