Wouldn't setting these be the same thing, except you need do it only once...
LTSCALE 0.5 (or 1.0 if using other definitions as MJF suggested)
MSLTSCALE 1
PSLTSCALE 1 (this needs to be set for each Layout)
The company has there msltscale set to 1 already. When I was at the office they couldn't get it keep the psltscale to set to one
in a layout. I believe why this has happened over and over is that these old dwg's that they were created in Eagle Point
and LDD so some variables didn't exist. I believe they went from 2004 LDD to Civil 3D 2011, quite a jump and a lot of
variables that needed to be added. Thus, my coding to help with the process. We are in the process of
redoing over 3 years worth of work done in that older format to C3D 2011. So, this won't be very normal for most of us. So, my routine
does reset those variables and fixes each layout when you run it. They were getting really annoyed having to set the
variables manually for so many dwg's and so many layouts... can you imagine?
MJP
