Author Topic: Scripr Error ?  (Read 4784 times)
Scripr Error ?
« Reply #15 on: November 28, 2004, 09:37:47 AM »
Got it working.
Turns out the explode command did not need the ""
So it only took 2 days to work out my first script. :shock:
Hope I get better on the next one. 8)
Crank
Scripr Error ?
« Reply #16 on: November 28, 2004, 10:17:26 AM »
Why don't you use
(COMMAND "insert" "*c:/opti/library/mpfixtur/_blocktag.dwg" "0,0" "1" "" "")
Then you don't have to explode at all!
Scripr Error ?
« Reply #17 on: November 28, 2004, 10:28:23 AM »
Good idea, Thanks.
