Author Topic: Searching for a thread about BBL  (Read 3040 times)
HasanCAD
« on: April 24, 2014, 03:21:03 AM »
I saw this thread before but cant reach could some one help me?
this thread about creating the bar bending schedule.
Thanks all
chlh_jd
Re: Searching for a thread about BBL
« Reply #1 on: April 24, 2014, 11:30:28 AM »
I don't know what ConsiderList you want , like ((Diameter ,  Tension-capacity) ( ... , ... )) ?
HasanCAD
« Reply #2 on: April 27, 2014, 07:02:14 AM »
My friend asked me for a lisp to create BBL (Bar Binding list) Or BBS (Bar Binding Schedule).
there are text on shopdrawing in special format ( for example: 3T16-6-200-B1) and this lisp grab these data and but in a table.
I saw this lisp in theswamp (I belive) and I want to ask the coder for comercial usage of this lisp.
chlh_jd
« Reply #3 on: May 01, 2014, 10:35:48 AM »
my humble opinion:
This is a list for design beams reinforced ,
3T16-6-200-B1
3 --> numbers of reinbar
T --> Steel material code , Like HRB400 , RRB500, ect.
16 --> reinbar diameter , mm
6 --> sectional area of 3T16 , 6cm*cm
200--> beam width , mm
B1 --> Reinforcement scheme code .
ROBBO
« Reply #4 on: May 02, 2014, 08:11:17 AM »
my humble opinion:
3T16-6-200-B1
This is a typical rebar call-up in the UK. (Although T is no longer used)
3T16-6-200-B1 3B16-6-200-B1
3 --> No. OFF
B --> STEEL TYPE (e.g. Grade B500B or B500C, denoted by B)
16 --> SIZE OF BAR (mm)
6 --> BAR MARK
200--> BAR CENTRES (mm)
B1 --> LOCATION (e.g. B1 = Bottom Layer nearest to concrete face)
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
ROBBO
« Reply #5 on: May 02, 2014, 09:06:44 AM »
Oscar Wilde
