Check if clip is present in the drawing
(1/1)
w64bit:
How I can check if a drawing contains clip?
ssget can help? If yes, someone knows if there is a group code for clip?
It's Alive!:
in the whole drawing? it's a Spatial Filter right?
this is python, maybe it can give a hint
--- Code - Python: ---import tracebackfrom pyrx_imp import Rx, Ge, Db, Ap, Ed def PyRxCmd_doit() -> None: try: db = Db.curDb() print(len(db.objectIds(Db.SpatialFilter.desc()))) except Exception as err: traceback.print_exception(err)
It's Alive!:
I found this
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/groupcode-for-an-xclip-or-how-to-access-it/m-p/856189
xdcad:
CLIP information is stored in the extended dictionary of the AcDbBlockReference (INSERT) object,
The Inspector tool can view
You can traverse all INSERTs to determine whether there is ACAD_FILTER
--- Code - Auto/Visual Lisp: ---(defun XD::Doc:HasFILTER (/ SS i bFound dict) (if (setq ss (ssget "x" '((0 . "Insert")))) (progn (setq i -1 bFound t ) (while (and bFound (setq e (ssname ss (setq i (1+ i))))) (setq ed (entget e)) (if (and (setq dict (cdr (assoc 360 ed))) (= (cdr (assoc 3 (entget dict))) "ACAD_FILTER") ) (setq bFound nil) ) ) (not bFound) ) ))
w64bit:
Thank you.
Is it possible, please, to add an alert when xclips are found?
Navigation
[0] Message Index
Go to full version
