Dent,
To change the Survey corrections settings
From the Projects menu, click Edit Drawing Settings to display the Edit Settings dialog box.
In the Program list, click Survey.
In the Settings list, click Corrections.
Click Edit Settings to display the Survey Correction Settings dialog box.
Choose the correction features that you want to apply to your data:
Curvature & Refraction: Corrects measurement calculations based on the curvature of the earth and refraction of the sun.
Sea Level: Includes corrections for sea level in all measurement calculations.
Atmospheric Conditions: Applies corrections for atmospheric conditions (pressure and temperature).
Horizontal Collimation: Works with FACE 1 and FACE 2 measurements only.
Vertical Collimation: Works with FACE 1 and FACE 2 measurements only. All vertical angles are converted to zenith.
Scale Factor: Includes corrections for the scale factor specific to horizontal distance in all measurement calculations.
EDM-Prism Eccentricity: Includes corrections for EDM and prism offsets in all calculations.
Click OK.
THEN, in the TRANSFORMATION SETTINGS box enter the values that you want Land to Apply when it uses the various transformation settings ON. In drawing settings, you are basically turning on a switch,
so that WHEN, and or IF you need to apply a particular transformation.
Importing the Field Book should then result in the transformations actually being applied.
Because you toggled them on, in the prototype, AND you toggled ON the Apply transformation
button, and entered the correct values in the right boxes.
