Author Topic: Count Blocks with Circles and Exploded Circles  (Read 4780 times)
MSTG007
« on: August 19, 2015, 05:35:34 PM »
I was searching on the web and found this link
http://www.cadforums.net/showthread.php/1748-entity-in-blocks
;;For nested blk
 ;;(tttt <objectname>)
 ;;(tttt "AcDbCircle")
 ;;By LUCAS
 (defun TTTT (OBJECTNAME / BLK BLKS COUNT ENT)
 (defun TTT1 (BLK / ENT)
 (vlax-for ENT (vla-item BLKS (vla-get-name BLK))
 ((= (vla-get-objectname ENT) OBJECTNAME)
 (setq COUNT (1+ COUNT))
 ((= (vla-get-objectname ENT) "AcDbBlockReference")
 (TTT1 ENT)
 (setq BLK (car (entsel "\nSelect Block: "))
 COUNT 0
 BLKS (vla-get-blocks
 BLK (vlax-ename->vla-object BLK)
 (TTT1 BLK)
 (vlax-release-object BLKS)
 COUNT
Again, no such luck trying to get it to do it. But I thought what the heck , I should ask!
Civil3D 2020
Re: Count Blocks with Circles and Exploded Circles
« Reply #1 on: August 19, 2015, 05:49:19 PM »
Exploded circles?  :?
ChrisCarlson
« Reply #2 on: August 24, 2015, 08:16:59 AM »
Maybe he means arcs? An exploded circle can be an arc but an arc cannot always be a circle.  :|
David Bethel
« Reply #3 on: August 24, 2015, 09:54:40 AM »
An ARC must be less than 360 Degrees
R12 Dos - A2K
MSTG007
« Reply #4 on: August 25, 2015, 07:46:12 AM »
Sorry guys for not getting back.. It was suppose to be circles within blocks and circles that are "exploded" or not part of a block. So it would count all circles in the selection set. Something like that.
Civil3D 2020
« Reply #5 on: August 25, 2015, 10:09:24 AM »
Well this counts circles... Maybe tie the "exploded circles" to a block by referencing the block insertion to the circle center point. Perhaps an example drawing?
  1. (alert (vl-prin1-to-string (length (ssget "_x" '((0 . "circle"))))))
MSTG007
« Reply #6 on: August 25, 2015, 10:32:38 AM »
here is what is in the drawing. I have a block that is a square with a circle in it copied a lot. Then I took the block and bursted it. (exploded wise). Finally I exploded the block. Object is to select with a window all the objects and just count how many circles are there.
Civil3D 2020
« Reply #7 on: August 25, 2015, 10:34:18 AM »
Just take the "_x" out of the code above.
ribarm
  • Marko Ribar, architect
« Reply #8 on: August 25, 2015, 10:52:07 AM »
I don't know, maybe just try this :
  1. (defun c:countcircles ( / countcircles *adoc* *blks* n )
  2.
  3.
  4.   (defun countcircles ( objcoll )
  5.     (vlax-for o objcoll
  6.       (cond
  7.         ( (= (vla-get-objectname o) "AcDbCircle")
  8.           (setq n (1+ n))
  9.         )
  10.         ( (vl-catch-all-error-p (vl-catch-all-apply 'vla-get-count (list o)))
  11.           nil
  12.         )
  13.         ( (/= (vla-get-count o) 0)
  14.           (countcircles o)
  15.         )
  16.       )
  17.     )
  18.   )
  19.
  20.   (setq *blks* (vla-get-blocks *adoc*))
  21.   (setq n 0)
  22.   (countcircles *blks*)
  23.   (alert (strcat "Total : " (itoa n) " circle entities bound/unbound to block(s)..."))
  24.   (princ)
  25. )
  26.
« Last Edit: August 25, 2015, 12:03:55 PM by ribarm »
M.R. on Youtube
MSTG007
« Reply #9 on: August 25, 2015, 11:15:18 AM »
Awesome. but I am getting an
C:COUNTCIRCLES
Command: COUNTCIRCLES
; error: ActiveX Server returned the error: unknown name: Count
Command:
Civil3D 2020
ribarm
« Reply #10 on: August 25, 2015, 12:05:59 PM »
I don't know... Try it now - slight change in the code...
M.R. on Youtube
MSTG007
« Reply #11 on: August 25, 2015, 12:46:23 PM »
That time the lisp executed and I had a popup box saying there is 526 circle entities bound/unbound to block(s)...
There are 525 circle entities. But there are 105 Blocks with circles in them.
I am guessing that it only count one block? other than that ... it does work!
Civil3D 2020
roy_043
  • BricsCAD 18
« Reply #12 on: August 25, 2015, 01:04:50 PM »
@ MSTG007: You have asked this question before:
http://www.theswamp.org/index.php?topic=49769.msg550267#msg550267
ribarm
« Reply #13 on: August 25, 2015, 01:05:25 PM »
If there are 525 circles, than it should count them as 525... I guess you missed one hidden to you somewhere in your DWG...
M.R. on Youtube
« Reply #14 on: August 25, 2015, 01:09:31 PM »
I would suggest:
  1. (defun c:cc ( / c d e i l s )
  2.     (while (setq d (tblnext "block" (not d)))
  3.         (setq e (tblobjname "block" (cdr (assoc 2 d)))
  4.               c 0
  5.         )
  6.         (while (setq e (entnext e))
  7.             (if (= "CIRCLE" (cdr (assoc 0 (entget e))))
  8.                 (setq c (1+ c))
  9.             )
  10.         )
  11.         (setq l (cons (cons (cdr (assoc 2 d)) c) l))
  12.     )
  13.     (setq c 0)
  14.     (if (setq s (ssget '((0 . "CIRCLE,INSERT"))))
  15.         (progn
  16.             (repeat (setq i (sslength s))
  17.                 (setq e (entget (ssname s (setq i (1- i)))))
  18.                 (if (= "CIRCLE" (cdr (assoc 0 e)))
  19.                     (setq c (1+ c))
  20.                     (setq c (+ c (cdr (assoc (cdr (assoc 2 e)) l))))
  21.                 )
  22.             )
  23.             (princ (strcat "\n" (itoa c) " circles found."))
  24.         )
  25.     )
  26.     (princ)
  27. )
