Author Topic: DIMENSION MESS IN DRAWING  (Read 5755 times)
SDETERS
« on: October 01, 2004, 02:56:40 PM »
When I put a dimension in this particular drawing I get GD&T blocks all over the place.  Also when I move my crosshairs across this drawing the cross hairs are very jumpy.
Please help
AUTOCAD 2004 XP
Also I have a image of what is going on but I do not know where or how to show it in this forum.
ELOQUINTET
« Reply #1 on: October 01, 2004, 02:59:25 PM »
forgive me but what are gd and t blocks?
SDETERS
« Reply #2 on: October 01, 2004, 03:04:20 PM »
There are used in Mechanical Drawings
Geometric dimension and tolerancing.
Like True postion and Flatness.
ELOQUINTET
« Reply #3 on: October 01, 2004, 03:08:53 PM »
if you are a member you can upload your image to the lilly pond then insert a link to it. are these symbols incorporatred into the dimensions style maybe. what happens if you try to purge the drawing
SDETERS
« Reply #4 on: October 01, 2004, 03:18:41 PM »
I can not post that Image in the lilly pond.
I can not get logged in.
ELOQUINTET
« Reply #5 on: October 01, 2004, 03:50:11 PM »
not sure what you mean go here
http://theswamp.org/lilly_pond
SDETERS
« Reply #6 on: October 01, 2004, 03:55:42 PM »
Yes I have it posted under the same topic.
This is what shows up after I pick the two lines I want to dimension and before I finish putting the dimension on the print.
http://www.theswamp.org/lilly_pond/Dimension_mess/gdt.bmp?nossi=1
PDJ
« Reply #7 on: October 01, 2004, 04:08:45 PM »
Holy Schnikes! I've NEVER seen an image come up that slow.. What the heck did you save it as!?!
SDETERS
« Reply #8 on: October 01, 2004, 04:12:32 PM »
A bmp file? Should I have saved it as a different type of file?  Sorry
t-bear
« Reply #9 on: October 01, 2004, 04:17:55 PM »
JPEG......TIFF
SDETERS
« Reply #10 on: October 01, 2004, 04:29:55 PM »
OOPS Sorry I have it saved as a JPG file now.  It is a lot smaller
CADaver
Re: DIMENSION MESS IN DRAWING
« Reply #11 on: October 01, 2004, 04:39:11 PM »
Quote from: SDETERS
Please help
AUTOCAD 2004 XP
Turn off toleranceing in the dimstyle??  Maybe?
SDETERS
« Reply #12 on: October 01, 2004, 04:54:08 PM »
Maybe this error message will help.
http://theswamp.org/lilly_pond/Dimension_mess/messageerror.JPG?nossi=1
It is a JPEG file
Ha
THanks
SDETERS
« Reply #13 on: October 11, 2004, 03:54:27 PM »
No one knows what this error might mean or any insight what so ever.  I will just have to redraw it.
« Reply #14 on: October 11, 2004, 04:32:28 PM »
The problem is likely due to corruption of third party objects in the drawing. It looks like the error message is telling you that some custom entity is not defined properly programatically. This cannot be fixed by you unless you erase the offending entities.
