Author Topic: C# and ObjectARX  (Read 4983 times)
C# and ObjectARX
« on: March 08, 2007, 08:43:31 AM »
I'm just curious if I need to download the ObjectARX stuff to get the most out of C#<->autocad?
Re: C# and ObjectARX
« Reply #1 on: March 08, 2007, 08:49:18 AM »
you don't "need to", but I think the samples and docs are very helpful, so its probably worth it to .
Dan
« Reply #2 on: March 08, 2007, 08:55:23 AM »
thanks Dan ....
Draftek
« Reply #3 on: March 08, 2007, 11:35:58 AM »
whOOoooT!
Welcome to the Dark Side, Mark.
« Reply #4 on: March 08, 2007, 03:45:23 PM »
You will at the very least need both the .net and arx help doc's.
Good Luck and have fun!
- John Carmack
- J.R.R. Tolkien
« Reply #5 on: March 08, 2007, 04:54:33 PM »
and the Labs will help for sure
Autocad 2007.Net Training.zip (zip - 788 Kb)
at http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
ObjectARX and .NET samples and documentation
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=773180
« Reply #6 on: March 08, 2007, 05:51:29 PM »
Also, be sure to have a soft wall or desk handy.....your forehead will appreciate it.
« Reply #7 on: March 08, 2007, 06:00:12 PM »
Yep, only initiates truly understand the necessity for a good banging place ...
Atook
  • AKA Tim
« Reply #8 on: March 08, 2007, 07:03:17 PM »
No, even seasoned perv- I mean experts appreciate the necessity for a good...
Nevermind.
fly_902
« Reply #9 on: March 12, 2007, 02:38:21 AM »
I think i need more about .net help!
