Author Topic: Multiple selection  (Read 1716 times)
au-s
Multiple selection
« on: May 12, 2009, 02:57:10 AM »
Hello
I have this lisp from LEEMAC on CADtutor which writes a script file and then executes a command in lisp:
Here is the code
(defun c:rscr  (/ wfile rfile ofile dir)
  (if (and (setq wfile "C:\\test.scr")
           (setq rfile (getfiled "\nSelect File from Directory to Read: " "" "dwg" 8)))
      (setq ofile (open wfile "w"))
      (foreach x  (vl-directory-files (setq dir (vl-filename-directory rfile)) "*.dwg" 1)
        (write-line
          (strcat "open \"" dir "\\" x "\" (load \"mylisp\") (c:mylisp) close \"Y\"")
          ofile))
      (close ofile)
      (command "script" wfile))
    (princ "\n<!> File Selection Error <!>"))
  (princ))
I cant multiple select files here.
I know that I can select files "multiple selection" without DCL and with DOSLib.
I wrote a bit of code and changed that.
Now .. with dos_getfilem I can choose multiple files.
But I think that the lisp cant understand whjat files are chosen when I try to writle-line to the script file... the format of it...
Can anyone help.
Here below is the code I tried to manipulate.
  (if (and (setq wfile "H:\\test.scr")
             (setq rfile (dos_getfilem "Select Drawings"
                             "" "DWG Files (*.dwg)|*.dwg"))
      (foreach rfile
        (write-line
          (strcat "open \"" rfile "\" (load \"mylisp\") (c:mylisp) close \"Y\"")
          ofile))
      (close ofile)
  (princ))
au-s
Re: Multiple selection
« Reply #1 on: May 12, 2009, 03:06:01 AM »
I modified but now it is nothing written into the file...
The file creates but it is empty and the output is cant open test.scr
(defun c:rscr  (/ wfile rfile ofile n)
      (foreach n
        '(write-line
          (strcat "open \"" rfile "\" (load \"K:/CAD/AIX-meny-2008/Lisp/attribut/AIX_ExportDörrLittera.lsp\") (c:AIX:EXPORTDORRLITT) close \"Y\"")
          ofile))
      (close ofile)
  (princ))
au-s
« Reply #2 on: May 12, 2009, 07:53:38 AM »
SOLVED with this one
(defun c:rscr  (/ flag thelist thedir nfiles thefile fn ctr dname)
;set the flag
(setq flag T)
;check Doslib is loaded
(if (not (member "doslib17.arx" (arx)))
    (if (findfile "doslib17.arx")
      (arxload "doslib17")
      (alert "DosLib not installed")
      (setq flag nil)
    );progn
   );if
  );progn
);if
;if DosLib is installed and loaded
(if flag
;do the following
  (setq thelist (dos_getfilem "Select Drawings"  "" "DWG Files (*.dwg)|*.dwg"))
;retrieve the directory
  (setq thedir (car thelist))
;retrieve the file names
  (setq thelist (cdr thelist))
;get the number of files
  (setq nfiles (length thelist))
  (setq thefile (strcat (dos_tempdir)"temp.scr"))
      (setq fn (open thefile "w"))
       (setq ctr 0)
        (repeat nfiles
    (setq dname (nth ctr thelist))
        (write-line
          (strcat "open \"" thedir dname "\" (load \"mylisp.lsp\") (c:mylisp) close \"Y\"")
          fn)
   (setq ctr (1+ ctr))
  );end repeat
      (close fn)
      (command "script" thefile)
    (princ "\n<!> File Selection Error <!>"))) (princ)))
Allthough it pronts out lots of error thingies .. anyone help?
