Code Red => AutoLISP (Vanilla / Visual) => Topic started by: ArgV on September 06, 2009, 06:05:18 PM
Hello.
I'm trying to make something that will just allow you to keep adding mleaders (the kind with the circle and attribute).
Basically I just want it to start at number 1 and keep going until the user stops or whatever, I wrote this little bit (doesn't work) for an example. Not sure if I'm even doing this right, but can't find anything on this subject directly.
(defun addCircleLeader (/ layout point1 point2 points cntr array leader)
(setq layout (vla-get-paperspace (vla-get-activedocument (vlax-get-acad-object))))
(repeat (getint "\nNumber of times to repeat:")
(setq
point1 (getpoint "\nSelect arrow point")
point2 (getpoint "\nSelect landing point")
points (list (car point1)(cadr point1)(caddr point1)(car point2)(cadr point2)(caddr point2))
cntr 1)
(setq array (vlax-make-variant
(vlax-safearray-fill
(vlax-make-safearray vlax-vbdouble
(cons 0 (1- (length points)))) points)))
(setq leader (vla-addmleader layout array cntr))
(vla-put-contentblockname leader "_TagCircle - Imperial")
(vla-setblockattributevalue leader (vla-get-objectid leader) (rtos cntr)) ;<-- doesn't like this..
(setq cntr (1+ cntr))
thanks in advance.
-ArgV
That's because you needed to search on >BUBBLE Click Here< (http://www.theswamp.org/index.php?action=search2;params=YWR2YW5jZWR8J3wxfCJ8YnJkfCd8MiwxMXwifHNob3dfY29tcGxldGV8J3x8InxzdWJqZWN0X29ubHl8J3x8Inxzb3J0X2RpcnwnfGRlc2N8Inxzb3J0fCd8cmVsZXZhbmNlfCJ8c2VhcmNofCd8YnViYmxl)
PS Haven't seen it done with Mleaders yet. :)
shouldn't (vla-get-objectid leader) be the attribute tag name?
on the mac, can't test right now.
also, why not use 'while' instead of 'repeat' then you can just pick until to don't want to, and it will continue to create mleaders with the attribute continuing to increase 1+
Like I say, I just threw this together to get the point across. I will be using a while statement, or some other mechanism. :-D
oh ok, never hurts to ask. :)
I hope not. If it did, I'd be a hurtin person! :angel:
Well CRAP! :x Thats it. I guess I found the extent of LISP's usefulness. Just when I thought everything could be done, !BAM! I find the *ONE* thing that can't!
Just kidding. Ok, well, at least I learned some things while searching around for bubbles. :) thanks.
-ArgV
I don't know. I was just trying to do what the (not real helpful) help file on qleaders said to do, or my interpretation of it. :|
Well, I put this together from a few different sources. There isn't alot of documentation on multi-leaders apparently. Kinda scary!
(thanks to Lee Mac for his contribution)
(defun c:aacl (/ layout point1 point2 points cntr array leader)
cntr 1)
(while
(setq
point2 (getpoint "\nSelect landing point" point1)
points (append point1 point2))
(setq leader (vla-addmleader layout array 0))
;This portion borrowed from code from Lee Mac..
;http://www.theswamp.org/index.php?topic=29271.0
(vla-SetDogLegDirection leader 0
(vlax-3D-point
(list
(if (<= (car point1) (car point2)) 1 -1) 0 0)))
(vla-put-dogleglength leader 0.1)
(vla-put-landinggap leader 0.1)
(addStuff)
(defun addStuff (/ ent entList attributeNames)
(setq ent (entlast))
(setq entList (entget ent))
(foreach item entList
(if (= (car item) 330)
(setq attributeNames (cons (vlax-ename->vla-object (cdr item))
attributeNames))
(vla-get-tagstring (nth 0 attributeNames))
(vla-SetBlockAttributeValue
(vlax-ename->vla-object ent)
(vla-get-objectid (nth 0 attributeNames))
(itoa cntr)
Thanks,
-ArgV
Hehe glad I could help in some way 8-)
