Author Topic: How to modify Dim variables ?  (Read 2475 times)
REGHUYES
« on: May 02, 2012, 10:34:09 PM »
How to modify Dim variables ( not override ) thro Autolisp .pls a simple code
irneb
Re: How to modify Dim variables ?
« Reply #1 on: May 03, 2012, 02:02:07 AM »
Easiest would be to use setvar to change the Dim* vars. Then use a command call to DimStyle with a Save option - to overwrite the current DimStyle with the new variables. That last step changes the overrides into the standard settings for the dimstyle.
More difficult method would be to entmod the dimstyle's object in the DimStyle table.
« Reply #2 on: May 03, 2012, 06:22:06 AM »
Alternatively, you can modify the various Dimension System Variables, then use the CopyFrom method with the Source Object parameter as the Active Document Object to copy the current settings to a supplied DimStyle Object.
« Reply #5 on: May 03, 2012, 03:53:57 PM »
Thanks Ron I didn't have that one.
I tried the usual URL tags but the link failed when I did that.
« Last Edit: May 03, 2012, 07:27:09 PM by CAB »
