Author Topic: Laydel  (Read 2884 times)
Fabricio28
Laydel
« on: June 13, 2013, 05:00:40 PM »
I'd like to change the default option of Laydel command.
After using the command
Do you wish to continue? [Yes/No]  <No>:
I wanna change for yes <Yes>. Is it possible?
BlackBox
Re: Laydel
« Reply #1 on: June 13, 2013, 05:21:00 PM »
  1. (defun c:FOO ()
  2.   (command "._laydel" pause "" "y")
  3.   (princ)
  4. )
  5.
Fabricio28
Re: Laydel
« Reply #2 on: June 13, 2013, 05:46:54 PM »
  1. (defun c:FOO ()
  3.   (princ)
  4. )
  5.
Hi BlackBox
Thank you for replay
Didn't work your code.
BlackBox
Re: Laydel
« Reply #3 on: June 13, 2013, 05:49:04 PM »
  1. (defun c:FOO ()
  3.   (princ)
  4. )
  5.
Hi BlackBox
Works fine here:
  1. Command: foo
  2. ._laydel
  3. Select object on layer to delete or [Name]:
  4. Selected layers: FOO.
  5. Select object on layer to delete or [Name/Undo]:
  6. ******** WARNING ********
  7.
  8. You are about to delete layer "FOO" from this drawing.
  9.
  10. Do you wish to continue? [Yes/No] <No>: y
  11.
  12. Deleting layer "FOO".
  13. 1 layer deleted.
  14. Hatch boundary associativity removed.
  15. Hatch boundary associativity removed.
  16.
Fabricio28
Re: Laydel
« Reply #4 on: June 13, 2013, 07:50:49 PM »
Whow! Really sorry about that. You were right.
Works fine.
I was in a bit of hurry and I made a mistake. :ugly:
Thank you very much!
 :-D
BlackBox
Re: Laydel
« Reply #5 on: June 15, 2013, 02:05:44 AM »
You're welcome; I'm happy to help. :beer:
