Code - Auto/Visual Lisp: [Select](defun c:FOO () (command "._laydel" pause "" "y") (princ))
Quote from: BlackBox on June 13, 2013, 05:21:00 PMCode - Auto/Visual Lisp: [Select](defun c:FOO () (command "._laydel" pause "" "y") (princ)) Hi BlackBoxThank you for replayDidn't work your code.
