It's your right. North arrow to LEFT, read from right (which would then be the BOTTOM.) Skip the decaf, get the strong stuff!!
That Corps manual gives a lot of info. If you try to download it, you better have a lot of paper. You can build your own CAD standards based on that manual and be in good shape. Note also that they have a pretty good block library there too.
