(vl-file-copy ff sf T)
Code: [Select](vl-file-copy ff sf T)
Nice
Nice function pBe.
COPY [/D] [/V] [/N] [/Y | /-Y] [/Z] [/L] [/A | /B ] source [/A | /B] [+ source [/A | /B] [+ ...]] [destination [/A | /B]] source Specifies the file or files to be copied. /A Indicates an ASCII text file. /B Indicates a binary file. /D Allow the destination file to be created decrypted destination Specifies the directory and/or filename for the new file(s). /V Verifies that new files are written correctly. /N Uses short filename, if available, when copying a file with a non-8dot3 name. /Y Suppresses prompting to confirm you want to overwrite an existing destination file. /-Y Causes prompting to confirm you want to overwrite an existing destination file. /Z Copies networked files in restartable mode. /L If the source is a symbolic link, copy the link to the target instead of the actual file the source link points to.The switch /Y may be preset in the COPYCMD environment variable.This may be overridden with /-Y on the command line. Default isto prompt on overwrites unless COPY command is being executed fromwithin a batch script.
