Code Red => AutoLISP (Vanilla / Visual) => Topic started by: francinez13 on April 23, 2024, 02:55:54 PM
I'm looking for a lisp to create multiple viewport.
I've found a lisp on this forum that almost meets my expectations, its name is NV.lsp. (see attached file)
I need 2 things, redo the same operation several times and insert the window not in the centre but in relation to a corner (for example the bottom left corner).
Does anyone know how to integrate this into this lisp?
Thank you very much in advance for the help
Do you want make viewports at scale to match a title block in Layouts like in this image the red rectangs have been made matching a MVIEW at scale. This is a slect P/Line and walk along or by placing rectangs, Rotation is supported by twisting view in layout.
(http://)
Yes, I need something like what you've drawn.
Do you have a Lisp so I can test it?
I also got an answer on the Autodesk forum, but I can only create one view after another. (see attached lisp). If possible it would be nice to select all View before inserting in the layout.
Post a dwg with a title block in a layout and what scale you want the view at. The advanced version asks for title block to be used and scale. Retrieving the title block from a master layouts dwg.
