Author Topic: Bursting a previously inserted block?  (Read 5676 times)
Joe Burke
Re: Bursting a previously inserted block?
« Reply #15 on: October 10, 2007, 09:08:00 AM »
Of course the downside of relying on burst is it's an ET command. Which may not be loaded or whatever...
It's not difficult to convert attributes to text using explode. That's what I do within the SuperFlatten routine.
KewlToyZ
« Reply #16 on: October 10, 2007, 10:34:03 AM »
I just use an old copy of burst that automatically selects all, thanks to CAB showing me how to do it.
Placed it into my support directory. The only reason is I can retain some objects like fixtures etc... while removing bound blocks of entire rooms. I just set the number of times to run the routine depnding on how nested the XREF's were before binding when I setup the background files.
(Defun C:MYBURST (/ item bitset bump att-text lastent burst-one burst
                  BCNT BLAYER BCOLOR ELAST BLTYPE ETYPE PSFLAG ENAME )
   ; Item from association list
   (Defun ITEM (N E) (CDR (Assoc N E)))
   ; Error Handler
  (acet-error-init
    (list
      (list "cmdecho" 0
            "highlight" 1
      T     ;flag. True means use undo for error clean up.
    );list
  );acet-error-init
   ; BIT SET
   (Defun BITSET (A B) (= (Boole 1 A B) B))
   ; BUMP
   (Setq bcnt 0)
   (Defun bump (prmpt)
      (Princ
         (Nth bcnt '("\r-" "\r\\" "\r|" "\r/"))
      (Setq bcnt (Rem (1+ bcnt) 4))
   ; Convert Attribute Entity to Text Entity
   (Defun ATT-TEXT (AENT / TENT ILIST INUM)
      (Setq TENT '((0 . "TEXT")))
      (ForEach INUM '(8
            6
            38
            39
            62
            67
            210
            10
            40
            1
            50
            41
            51
            7
            71
            72
            73
            11
            74
         (If (Setq ILIST (Assoc INUM AENT))
            (Setq TENT (Cons ILIST TENT))
      (Setq
         tent (Subst
                 (Cons 73 (item 74 aent))
                 (Assoc 74 tent)
                 tent
      (EntMake (Reverse TENT))
   ; Find True last entity
   (Defun LASTENT (/ E0 EN)
      (Setq E0 (EntLast))
      (While (Setq EN (EntNext E0))
         (Setq E0 EN)
      E0
   ; See if a block is explodable. Return T if it is,
   ; otherwise return nil
   (Defun EXPLODABLE (BNAME / B expld)
      (setq BLOCKS (vla-get-blocks
                     (vla-get-ActiveDocument (vlax-get-acad-object)))
      (vlax-for B BLOCKS (if (and (= :vlax-false (vla-get-islayout B))
                                  (= (strcase (vla-get-name B)) (strcase BNAME)))
                      (setq expld (= :vlax-true (vla-get-explodable B)))
       expld
   ; Burst one entity
   (Defun BURST-ONE (BNAME / BENT ANAME ENT ATYPE AENT AGAIN ENAME
                     ENT BBLOCK SS-COLOR SS-LAYER SS-LTYPE mirror ss-mirror
                     mlast)
      (Setq
         BENT   (EntGet BNAME)
         BLAYER (ITEM 8 BENT)
         BCOLOR (ITEM 62 BENT)
         BBLOCK (ITEM 2 BENT)
         BCOLOR (Cond
                   ((> BCOLOR 0) BCOLOR)
                   ((= BCOLOR 0) "BYBLOCK")
                   ("BYLAYER")
         BLTYPE (Cond ((ITEM 6 BENT)) ("BYLAYER"))
      (Setq ELAST (LASTENT))
      (If (and (EXPLODABLE BBLOCK) (= 1 (ITEM 66 BENT)))
         (Progn
            (Setq ANAME BNAME)
            (While (Setq
                      ANAME (EntNext ANAME)
                      AENT  (EntGet ANAME)
                      ATYPE (ITEM 0 AENT)
                      AGAIN (= "ATTRIB" ATYPE)
               (bump "Converting attributes")
               (ATT-TEXT AENT)
         (Progn
            (bump "Exploding block")
            (acet-explode BNAME)
            ;(command "_.explode" bname)
      (Setq
         SS-LAYER (SsAdd)
         SS-COLOR (SsAdd)
         SS-LTYPE (SsAdd)
         ENAME    ELAST
      (While (Setq ENAME (EntNext ENAME))
         (bump "Gathering pieces")
         (Setq
            ENT   (EntGet ENAME)
            ETYPE (ITEM 0 ENT)
         (If (= "ATTDEF" ETYPE)
            (Progn
               (If (BITSET (ITEM 70 ENT) 2)
                  (ATT-TEXT ENT)
               (EntDel ENAME)
            (Progn
               (If (= "0" (ITEM 8 ENT))
                  (SsAdd ENAME SS-LAYER)
               (If (= 0 (ITEM 62 ENT))
                  (SsAdd ENAME SS-COLOR)
               (If (= "BYBLOCK" (ITEM 6 ENT))
                  (SsAdd ENAME SS-LTYPE)
      (If (> (SsLength SS-LAYER) 0)
         (Progn
            (bump "Fixing layers")
            (Command
               "_.chprop" SS-LAYER "" "_LA" BLAYER ""
      (If (> (SsLength SS-COLOR) 0)
         (Progn
            (bump "Fixing colors")
            (Command
               "_.chprop" SS-COLOR "" "_C" BCOLOR ""
      (If (> (SsLength SS-LTYPE) 0)
         (Progn
            (bump "Fixing linetypes")
            (Command
               "_.chprop" SS-LTYPE "" "_LT" BLTYPE ""
   ; BURST MAIN ROUTINE
   (Defun BURST (/ SS1)
      (setq PSFLAG (if (= 1 (caar (vports)))
                       1 0
      ;(setq ss1 (ssget "_X" ))
      (Setq SS1 (SsGet "_X" (list (cons 0 "INSERT")(cons 67 PSFLAG))))
      (If SS1
         (Progn
            (Setvar "highlight" 0)
            (terpri)
            (Repeat
               (SsLength SS1)
               (Setq ENAME (SsName SS1 0))
               (SsDel ENAME SS1)
               (BURST-ONE ENAME)
            (princ "\n")
   ; BURST COMMAND
   (BURST)
  (acet-error-restore)
);end defun
Joe Burke
« Reply #17 on: October 10, 2007, 12:32:13 PM »
Hacking old code which you don't fully understand is a recipe for problems down the road.
Roll your own which you fully understand.
