Author Topic: select all grips in one location  (Read 3103 times)
Dr. After
« on: July 27, 2005, 12:29:54 PM »
It used to be that any overlapping grips would move as one entity, but now if I have two or more grips in one location I have to move them one at a time.  Anyone know of a variable for this?  I would like to be able to sleect the grip and have all in that location follow the lead.
« Reply #1 on: July 27, 2005, 03:47:21 PM »
Using ACAD2000 I use the ALT key plus left mouse to move the highlited items.
Is that what you are trying to do?
If you use the shift key the items are copied.
Dr. After
« Reply #2 on: July 28, 2005, 10:10:26 AM »
nonono...  I'm talking about if you have three lines that end at the same point but come from different directions.  You want to move the point where they meet by using only grips.  So you selec each line so all grips are shown on all three lines.  Then you select the grip where they all meet and drag it to some new location.  It used to move all three, but now it only takes one at random.  How can I get it to move all three again?
daron
« Reply #3 on: July 28, 2005, 10:20:19 AM »
CAB, I think we're going to have to defer this to someone with 2006. I hope there's some kind of variable that affects this. If this isn't inclusive to 2006, try looking at some options under the selection tab. Hopefully, you'll find something there.
Dr. After
« Reply #4 on: July 28, 2005, 12:50:08 PM »
I can't find anything relative to this so far.  I have looked heavily in the options GUI and the help files, but have come up with nothing.  It is a real PITA...
daron
« Reply #5 on: July 28, 2005, 12:52:40 PM »
Hello, 2006'ers. Your presence is needed. Beuller?
« Reply #6 on: July 28, 2005, 02:04:25 PM »
Perhaps a different approach will get the job done....STRETCH.
Dr. After
« Reply #7 on: July 28, 2005, 03:45:37 PM »
I wanna take advantage of grips, though.  They are handy and quick.  Let's not argue which is quicker ;-) lets just find out how to get this to work again.
Dr. After
« Reply #8 on: August 01, 2005, 11:33:26 AM »
Well...  after a freash reinstall it all appears to be normal.  No veriable yet, that I can find either.
