Code Red => AutoLISP (Vanilla / Visual) => Topic started by: gswang on May 22, 2013, 09:40:03 PM
Where can i find DynDraw.arx for autocad2014 version ?
thanks a lot. :|
Post in this thread and maybe Alexander Rivilis will get the notification.http://www.theswamp.org/index.php?topic=9133.30
thanks a lot. :|
As usually last version of DynDraw can be downloaded from http://www.maestrogroup.com.ua/support/dyndraw.zip
DynDraw2013x32.arx and DynDraw2013x64.arx have to work with AutoCAD 2014.
Ok, thank you, CAB, Alexander!
Hi Alexander...
Will you be re-compiling so DynDraw works with AutoCad 2015.
I'd be lost without it... I'd have to stay with ACAD 2014.
Thank you for a great add-on for AutoCAD.
ditto for selsim and geomprops
please recompile
thank you in advance
Alexander,
many thanks
Thanks for that link Tony... but I guess we wait for support for 2015.
Thanks Alexander for a great piece of code that changes the way I draw.
Hi, Alexander Rivilis, Is there DynDraw.arx for autocad2016?
what does DynDraw do?
https://www.theswamp.org/index.php?topic=30650.msg386337#msg386337
thanks a lot. :|
As usually last version of DynDraw can be downloaded from http://www.maestrogroup.com.ua/support/dyndraw.zip (http://www.maestrogroup.com.ua/support/dyndraw.zip)
Hello,
Any updates for 2025 arx?
Link to page doesn't work.
maybe here https://adn-cis.org/assets/files/
maybe here https://adn-cis.org/assets/files/ (https://adn-cis.org/assets/files/)
it is there. Thanks!
