Have you applied the view settings to all tabs? (it's an option under the view dialog)
Are these palettes located in a read-only folder? If it is, when you change the view setting, it won't be able to resave the palette definition. When you change the workspace, or change the tab, it may be reloading the palette definition that isn't reflecting your chagnes.
