Code Red => AutoLISP (Vanilla / Visual) => Topic started by: POCKETS on August 05, 2008, 04:51:50 PM
How do you get the attached program to work? I am use to seeing a "defun C:" when I load a lisp program and this one doesn't have it. Why? I am using R2002.
Many thanks in advance.
Pockets
;;; CADALYST 07/08 www.cadalyst.com/code
;;; Tip 2301: QS.lsp Quadrant Snap (c) 2008 John Loudermilk
;QS.LSP
;Snap to 45 degree angles on circle.
(defun QS (/ NO_ENTITY SS ELIST PT0 CP R A PT)
<code removed: see link to get code>
;Return existing error handler
(setq *error* ExistError)
(princ))
;End QS.LSP
Type (QS) at the command line OR
Change this line
to this:
(defun c:QS (/ NO_ENTITY SS ELIST PT0 CP R A PT)
and type QS at the command line.
Thanks CAB. That worked.
