Author Topic: Hatch area with 2 picks  (Read 2991 times)
GDF
« on: December 26, 2005, 03:38:55 PM »
Anyone have a routine that will hatch an area with only two picks?
The hatch area would be 5'-0" perpendicular from each side of the hatch area
centerline <see image>.
Gary
nivuahc
Re: Hatch area with 2 picks
« Reply #1 on: December 26, 2005, 04:24:13 PM »
shouldn't be too difficult to write sonething Gary. I don't have AutoCAD at my disposal so I'd be running on "I think this is what you need" and I don't have enough faith in my memory to do that. ;)
nivuahc
« Reply #2 on: December 26, 2005, 04:26:41 PM »
This is how I would do it, off the top of my head, in pseudo-code:
get the two points
calculate the offsets
draw a closed polygon boundary
select the boundary
hatch it
should be simple enough
« Reply #3 on: December 26, 2005, 04:42:18 PM »
Gary
Here is a start.
(defun c:myhatch (/ ang dist hscale p1 p2 rb usercmd useros rtd)
  (defun rtd (r) (* 180.0 (/ r pi)))
  (setq usercmd (getvar "CMDECHO")
        useros  (getvar "osmode")
        dist    60  ; 5' distance
        hscale  100 ; Hatch Scale
        rb      "Y" ; retain border
  (setvar "CMDECHO" 0)
  (setq p1 (getpoint "\nPick first point of Centerline."))
  (setq p2 (getpoint p1 "\nPick second point of Centerline."))
  (setq ang (angle p1 p2))
  (setvar "osmode" 0)
  (command "_.hatch" "ANSI31" hscale (rtd ang) "" rb
           (polar p1  (+ ang (* pi 0.5)) dist)
           (polar p2  (+ ang (* pi 0.5)) dist)
           (polar p2  (- ang (* pi 0.5)) dist)
           (polar p1  (- ang (* pi 0.5)) dist)
           "close" ""
  (setvar "CMDECHO" usercmd)
  (setvar "osmode" useros)
« Reply #4 on: December 26, 2005, 05:20:45 PM »
Here's one using ActiveX....
(defun c:2phatch (/ a ang b c coords d dist doc hatch pline pt1 pt2 space)
  (while (and (setq pt1 (getpoint "\nFirst point: "))
      (setq pt2 (getpoint pt1 "......second point: "))
    (setq ang (angle pt1 pt2)
  dist (if (or (= 3 (getvar "lunits"))
       (= 4 (getvar "lunits"))
60.0
5.0)
    (setq a (polar pt1 (+ ang (/ pi 2)) dist)
  d (polar pt1 (- ang (/ pi 2)) dist)
  b (polar pt2 (+ ang (/ pi 2)) dist)
  c (polar pt2 (- ang (/ pi 2)) dist)
    (setq coords (apply 'append (mapcar '(lambda (x)
    (list (car x) (cadr x))
(list a b c d)
    (setq doc (vla-get-activedocument (vlax-get-acad-object))
  space (if (= 1 (getvar "cvport"))
  (vla-get-paperspace doc)
  (vla-get-modelspace doc)
  pline (vlax-invoke space 'addlightweightpolyline coords)
    (vla-put-closed pline :vlax-true)
    (setq hatch (vlax-invoke space 'addhatch acHatchPatternTypePredefined "ANSI31" :vlax-false))
    (vlax-invoke hatch 'appendouterloop (list pline))
    (vlax-put hatch 'patternangle ang)
    (vlax-put hatch 'patternscale (getvar "hpscale"))
    (vlax-invoke hatch 'evaluate)
GDF
« Reply #5 on: December 26, 2005, 05:51:21 PM »
Thanks eveyone. I was just too lazy to even start one. Jeff and Allen, both work great.
Thanks. You saved me a lot of time.
Gary
