Author Topic: New menu loading problems  (Read 34427 times)
ELOQUINTET
« on: November 12, 2003, 09:12:07 AM »
hey mark i went home last night and created new  (DAN) mns mnc and mnl files using your tutorial as a guide. i copied them to a usb drive and brought them into work and put them in a folder called menus within my lisp files folder in my documents. then i opened acad and did menuload and all of my toolbars showed up except i had created some custom flyouts for offsets and fillets. my custom toolbars are not in my toolbars dialog to associate with the flyouts. i also didn't have any autocad pulldowns so i believe i unloaded it then loaded the acad mnu then customized it which created an mns. then i unloaded the acad mnu and loaded the acad mns. then reloaded my mns. file. i also loaded a couple other menus like the adt and some pulldowns i have which have decimal equivalents sheet metal gauges and parts now. i had eveything setup just how i wanted so i closed acad (brave). well when i reopened acad all i have is the parts now toolbar. so i followed the same steps as previous and when i installed my mns some of my icons showed up and some had smileys. so this is where i am now. if you could help me sort this mess out i would greatly appreciate it. thanks
dan
M-dub
« Reply #1 on: November 12, 2003, 09:19:45 AM »
I won't say much...don't worry...
As far as the smiley faces are concerned, I would like to suggest Resource Hacker to create a dll file that accompanies your partial menu...
I'm not sure, but I think there was a bit of a tutorial on Afralisp about using this program to do this.  Of course, I didn't find the tutorial until after I'd pulled all of my hair out trying to figure it out for myself!
Highly Recommended!!!
daron
« Reply #2 on: November 12, 2003, 09:21:05 AM »
The .mns file will create the .mnr, .mnc and I believe the .mnu file. .mnl is optional, I think. As far as menus not loading, try loading acad.mns first, then the rest. Dan.mns should be the last one you load. Can you copy and paste some of your .mns file and is your dll file (I assume you have one) named Dan.dll?
ELOQUINTET
« Reply #3 on: November 12, 2003, 11:07:58 AM »
hey guys i haven't got time to test things out right now as i was just handed a big job to do but i will take your advice daron. by the way i didn't download the dll creator software :roll: that mark told me to so i guess that will solve the smiley   :evil:   problem. how can i solve the problem of my custom toolbars not showing up. can i copy them somehow from home to here and not have to create them again cos that was a bit tedious. also what were you saying about cutting and pasting daron. thanks guys. o yeah uhhum daron how do i get the between feature the showup in my snaps without losing everything else (not pointing fingers :lol: ) thanks folks
dan
M-dub
« Reply #4 on: November 12, 2003, 11:25:54 AM »
In your DAN.mn*, what is the name of the menugroup?  One reason why you might not be getting your toolbars could be because you've left it as ACAD.  It'll have to be unique.  I'd do MENUGROUP=DAN
I ain't even gonna touch the osnap menu...I wanna see what Daron or Mark have to say...(not being pointed at...  :wink: )
Cheers,
Mike
ELOQUINTET
« Reply #5 on: November 12, 2003, 11:33:51 AM »
changed all my menugroups but thanks for lookin out mdub. btw see my post about your smoking or rather "not". cheers
dan
daron
« Reply #6 on: November 12, 2003, 12:13:26 PM »
All your custom toolbars are in the Dan.mns file. Even if they are a bunch of smiley's or in 2004's case ?'s on clouds, they should still work. Could you post your mns file so we can see it. You can even upload it on the lily pond and link us to it.
That has to be done in the acad.mns file, unless you'd rather have a toolbar that invokes it. It shouldn't delete anything. Always make a backup copy or something before modifying anything.
« Reply #7 on: November 12, 2003, 12:17:25 PM »
Let me ask you this first, did you add the new "menu" folder to the acad search path?
M-dub
« Reply #8 on: November 12, 2003, 12:32:05 PM »
Quote from: Daron
If you create a toolbar for it, leave the ^C^C out of the macro...Just use 'btwn.  Otherwise, it cancels the command you're in.
daron
« Reply #9 on: November 12, 2003, 12:35:20 PM »
^Oh, yeah! Do that.
ELOQUINTET
« Reply #10 on: November 12, 2003, 12:50:40 PM »
wow you guys all pounced on me at once. ok first i'll answer marks question. i did add mydocuments\lisp files to my search path but put the menus in a subfolder called menus. do i have to be more specific? second i added between to DAN.mns i believe. so you're saying i should add it to acad.mns ok. i created 3 toolbars called custom offest 1 custom offset 2 and custom fillet. each button has  various offsets and fillets. then i made  3 flyouts and attached the toolbar to the flyouts. when i open acad i have the flyouts but in my toolbars the ones i created are not there to attach. am i missing something or doing this a bad way? thanks for the help guys
dan
« Reply #11 on: November 12, 2003, 12:54:49 PM »
yes
If you're creating the new toolbars in your new menu group then you shouldn't have a problem.
« Reply #12 on: November 12, 2003, 01:01:06 PM »
You might also want to re-read my custom menu help file (Fifth step) one more time.
ELOQUINTET
« Reply #13 on: November 12, 2003, 01:02:32 PM »
yeah i thought that was a dumb question you should've given me a dumb answer. i created a path for my menus. i was just trying to go add the betwwen to my acad.mns and again i don't see one. i went to menuload and selected mns at bottom and went to my support folder. i swore it was there this morning. what's going on?
dan
« Reply #14 on: November 12, 2003, 01:19:31 PM »
Alright, let's start over. But first let's make sure you know were every thing is. :D
Can you find the 'acad.mnu' file?
Do you know how to load the ADT menus?
