Author Topic: Quickly Inserting Blocks  (Read 5040 times)
Re: Quickly Inserting Blocks
« Reply #15 on: May 05, 2010, 07:42:56 AM »
MP,
I'm using it for the speed verses vla-insert. The entmake is about 5 times faster in AutoCAD 2009. I tried the entlast to vla method and entmake (cdr (assoc -1)) but then all the speed gains were lost. I guess the more version independent universal method is to insert via vla.
Thanks for taking the time to reply :).
« Reply #16 on: May 05, 2010, 07:52:43 AM »
When using the entmake method - I assume that the Inserts can only be 'entmade' if the block definition exists in the block table, so if it doesn't would you use something like:
(command "_.insert" <block filepath>) (command)
To create it?
I don't see this problem with vla-insert, I suppose thats the sacrifice of speed.  :|
« Reply #17 on: May 05, 2010, 08:11:01 AM »
Lee,
The block definition already exists in the drawing. I really wish this entmake behaved the same between acad versions.  :-(
« Reply #18 on: May 05, 2010, 08:29:54 AM »
Oh right  :-)
I was just considering the case in which it didn't  :-)
« Reply #19 on: May 05, 2010, 08:38:33 AM »
You're very welcome Ron. Parting gift:
reliability > speed
« Reply #20 on: May 05, 2010, 10:21:29 AM »
Just to be clear, this took a big performance hit over entmakex?
(defun rjp-insertcan2 (pt layer sc val / elst)
  (if (setq elst
             (entmake (list '(0 . "INSERT")
                            '(100 . "AcDbEntity")
                            '(100 . "AcDbBlockReference")
                            '(2 . "RJP_CatchCan")
                            (cons 8 layer)
                            (cons 10 pt)
                            (cons 41 sc)
                            (cons 42 sc)
                            (cons 43 sc)
                            (cons -3 (list (cons "Precipitation" (list (cons 1040 val)))))
    (vlax-ename->vla-object (cdr (assoc -1 elst)))
« Reply #21 on: May 05, 2010, 04:13:52 PM »
CAB,
From the test I did the insertion time went to over 40 seconds  :?(compared to 6.5). I'll give it another test when I get back to the office.
« Reply #22 on: May 05, 2010, 05:10:57 PM »
If it is the same block, can you just insert it once, and then copy it to the other points?
« Reply #23 on: May 05, 2010, 06:24:24 PM »
I suppose I could try that :) Thanks Tim.
« Reply #24 on: May 05, 2010, 06:57:31 PM »
CAB,
Well I ran the test again...these two were just about the same:
    (entmakex (list '(0 . "INSERT")... vs. (entmakex then (vlax-ename->vla-object (entlast))
The (if (setq el ... (vlax-ename->vla-object (cdr (assoc -1 el))) kept breaking in 2009 with that same invalid entity name error i was seeing in 2008. :pissed:
