(defun Dxf (DxfCod EntDat) (cdr (assoc DxfCod EntDat)))
(DXF 1 (cdr (DXF 1 (cdr (DXF 1 #Info6_Index))))) => ("Tropicana" "Vitamin E" "Protein 7" "1.1")
(DXF 2 (cdr (DXF 2 (cdr (DXF 1 #Info6_Index))))) => (nil)
(nth 1 (cdr (nth 1 (cdr (nth 1 #Info6_NO_Index))))) => ("Tropicana" "Vitamin E" "Protein 7" "1.1")
(nth 2 (cdr (nth 2 (cdr (nth 1 #Info6_NO_Index))))) => (nil)
(setq #Info6_NO_Index '(
("SubGroup 0"
("Class 00"
("SubClass 000" "000 DescriptionA" "000 DescriptionB" "000 Measure")
("SubClass 001" "001 DescriptionA" "001 DescriptionB" "001 Measure")
("SubClass 002" "002 DescriptionA" "002 DescriptionB" "002 Measure")
("Class 01"
("SubClass 010" "010 DescriptionA" "010 DescriptionB" "010 Measure")
("SubClass 011" "011 DescriptionA" "011 DescriptionB" "011 Measure")
("SubClass 012" "012 DescriptionA" "012 DescriptionB" "012 Measure")
("Class 02"
("SubClass 020" "020 DescriptionA" "020 DescriptionB" "020 Measure")
("SubClass 021" "021 DescriptionA" "021 DescriptionB" "021 Measure")
("SubClass 022" "022 DescriptionA" "022 DescriptionB" "022 Measure")
("Fruits"
("Apple"
("Winesap" "Vitamin A" "Protein 2" "5.5")
("McIntosh" "Vitamin B" "Protein 3" "7.6")
("Granny Smith" "Vitamin C" "Protein 1" "2.8")
("Orange"
("Valencia" "Vitamin D" "Protein 5" "2.2")
("Generic" "Vitamin F" "Protein 9" "1.9")
(nil
(nil)
(nil)
(nil)
("SubGroup 2"
("Class 20"
("SubClass 200" "200 DescriptionA" "200 DescriptionB" "200 Measure")
("SubClass 201" "201 DescriptionA" "201 DescriptionB" "201 Measure")
("SubClass 202" "202 DescriptionA" "202 DescriptionB" "202 Measure")
("Class 21"
("SubClass 210" "210 DescriptionA" "210 DescriptionB" "210 Measure")
("SubClass 211" "211 DescriptionA" "211 DescriptionB" "211 Measure")
("SubClass 212" "212 DescriptionA" "212 DescriptionB" "212 Measure")
("Class 22"
("SubClass 220" "220 DescriptionA" "220 DescriptionB" "220 Measure")
("SubClass 221" "221 DescriptionA" "221 DescriptionB" "221 Measure")
("SubClass 222" "222 DescriptionA" "222 DescriptionB" "222 Measure")
(setq #Info6_Index '(
(0 "SubGroup 0"
(0 "Class 00"
(0 "SubClass 000" "000 DescriptionA" "000 DescriptionB" "000 Measure")
(1 "SubClass 001" "001 DescriptionA" "001 DescriptionB" "001 Measure")
(2 "SubClass 002" "002 DescriptionA" "002 DescriptionB" "002 Measure")
(1 "Class 01"
(0 "SubClass 010" "010 DescriptionA" "010 DescriptionB" "010 Measure")
(1 "SubClass 011" "011 DescriptionA" "011 DescriptionB" "011 Measure")
(2 "SubClass 012" "012 DescriptionA" "012 DescriptionB" "012 Measure")
(2 "Class 02"
(0 "SubClass 020" "020 DescriptionA" "020 DescriptionB" "020 Measure")
(1 "SubClass 021" "021 DescriptionA" "021 DescriptionB" "021 Measure")
(2 "SubClass 022" "022 DescriptionA" "022 DescriptionB" "022 Measure")
(1 "Fruits"
(0 "Apple"
(0 "Winesap" "Vitamin A" "Protein 2" "5.5")
(1 "McIntosh" "Vitamin B" "Protein 3" "7.6")
(2 "Granny Smith" "Vitamin C" "Protein 1" "2.8")
(1 "Orange"
(0 "Valencia" "Vitamin D" "Protein 5" "2.2")
(1 "Tropicana" "Vitamin E" "Protein 7" "1.1")
(2 "Generic" "Vitamin F" "Protein 9" "1.9")
(2 nil
(0 nil)
(1 nil)
(2 nil)
(2 "SubGroup 2"
(0 "Class 20"
(0 "SubClass 200" "200 DescriptionA" "200 DescriptionB" "200 Measure")
(1 "SubClass 201" "201 DescriptionA" "201 DescriptionB" "201 Measure")
(2 "SubClass 202" "202 DescriptionA" "202 DescriptionB" "202 Measure")
(1 "Class 21"
(0 "SubClass 210" "210 DescriptionA" "210 DescriptionB" "210 Measure")
(1 "SubClass 211" "211 DescriptionA" "211 DescriptionB" "211 Measure")
(2 "SubClass 212" "212 DescriptionA" "212 DescriptionB" "212 Measure")
(2 "Class 22"
(0 "SubClass 220" "220 DescriptionA" "220 DescriptionB" "220 Measure")
(1 "SubClass 221" "221 DescriptionA" "221 DescriptionB" "221 Measure")
(2 "SubClass 222" "222 DescriptionA" "222 DescriptionB" "222 Measure")
It is better to get the data through the position (nth) or through assoc?assoc'ed lists is one of the advantaged of lisp over other 'array oriented' languages
Marko & Grrr1337, if you look at all my examples I have never used the key to access the data but only the index:
I agree with you even though I am surprised by this result:It is better to get the data through the position (nth) or through assoc?assoc'ed lists is one of the advantaged of lisp over other 'array oriented' languages
it makes lists much easier to manage
why deprive yourself of this?
i would assoc every atom in the list
(defun GetByAssoc (k1 k2 k3)
(cdr (assoc k3 (cddr (assoc k2 (cddr (assoc k1 #Info6_Index))))))
(defun GetByNth (k1 k2 k3)
(nth k3 (cdr (nth k2 (cdr (nth k1 #Info6_NO_Index)))))
Elapsed milliseconds / relative speed for 131072 iteration(s):
(GETBYNTH 0 0 0).......1437 / 2.27 <fastest>
(GETBYASSOC 0 0 0).....3266 / 1 <slowest>
(GETBYNTH 5 5 5).......1328 / 1.08 <fastest>
(GETBYASSOC 5 5 5).....1437 / 1 <slowest>
(GETBYASSOC 9 9 9).....1375 / 1.03 <fastest>
(GETBYNTH 9 9 9).......1421 / 1 <slowest>
Is your question "What is better to use: assoc or nth?"
If my list doesn't depents on the keys, but rather subitem's positions then I'd use something like:Code - Auto/Visual Lisp: [Select]
Comando: (nnth '(2 2 2) #Info6_NO_Index)
Comando: (nnth '(1 1 1) #Info6_NO_Index)
Comando: (nnth '(1 0 2) #Info6_NO_Index)
; errore: tipo di argomento errato: consp "Fruits
(defun nnth ( nL L )
(while (and nL L (listp L))
(setq L (nth (car nL) L)) (setq nL (cdr nL))
L
(defun AssocOrNth ( anL L / n )
(while (and anL L (listp L))
(setq n (car anL))
(setq L
( (eq 'INT (type n)) (nth n (cdr L)) )
( (assoc n (cdr L)) )
(setq anL (cdr anL))
L
Example with full list of 1000 Class: 10 SubGroup - 100 Class - 1000 SubClass
Mediumly the density of data can be:
a) SubGroup = 10 > 1 empty
b) Classes = 100 > 15 empty in the not empty SubGroups
c) SubClasses = 1000 > 180 empty in the not empty SubGroups or Classes
So my SubClass are:
a) 1000 - 100 = 900
b) 900 - (15 x 10) = 750
c) 750 - 180 = 570
