Author Topic: Batch Plotting Portrait & Landscape Drawings  (Read 4192 times)
M-dub
« on: March 20, 2008, 03:19:35 PM »
I think I'm wishful thinking here, but is there some way to be able to load a bunch of drawings into a Batch Plotter that may be oriented Portrait OR Landscape and have the software recognize which orientation to have them printed at?
Did that make sense?
Again, I don't think this is possible... maybe this is just a mini-vent.  :)
Atook
  • AKA Tim
Re: Batch Plotting Portrait & Landscape Drawings
« Reply #1 on: March 20, 2008, 04:19:16 PM »
The only work around I can think of, maybe plot to PDF and then print the pdf?
« Reply #2 on: March 20, 2008, 04:52:37 PM »
Maybe this could be modified to recognize if the width is greater than the height and set to plot at landscape....or vise versa.
http://www.theswamp.org/index.php?topic=20863.msg256151#msg256151
Kate M
« Reply #3 on: March 20, 2008, 04:56:04 PM »
Won't PUBLISH do that, if you have your page setups defined?
Bob Wahr
« Reply #4 on: March 20, 2008, 06:27:56 PM »
Why yes, yes it will.  You don't even have to have page setups defined, if your layout is set to plot it the way you want it plotted.
uncoolperson
« Reply #5 on: March 20, 2008, 11:27:14 PM »
maybe a quick lisp to find the longer side then print based off that?
