Author Topic: Moving Point now changes elevation?  (Read 11268 times)
« on: May 23, 2012, 10:38:31 AM »
In prior versions of C3D if I grab the grip of a Point and moved it the elevation of the point would not change. Now in C3D 2013 if I move a point using the grip the elevation changes to zero. Is there a setting I can change to get back the old behavior? OSNAPZ doesn't seem to have an effect one way or the other.
thanks
Re: Moving Point now changes elevation?
« Reply #1 on: May 23, 2012, 11:50:48 AM »
sugget you turn off 3D Object Snap  (F4)
« Reply #2 on: May 23, 2012, 12:40:37 PM »
it was off. thanks though.
« Reply #3 on: May 24, 2012, 12:17:30 AM »
what are these points you are moving and why?
huiz
  • Certified Prof C3D
« Reply #4 on: May 24, 2012, 04:09:50 AM »
In 2013 and in 2012 the behavior is the same, if I move a Point or a Cogo Point with grips, the Z remain as it was.
I don't have your problem, so it is not something new in 2013.
« Reply #5 on: May 24, 2012, 07:57:07 AM »
If you draw a line with both Z values at 0.00 then drag a point over to the line and snap the end point or mid point then check the Z value of the Point. In previous version the point would retain its value and ignore the Z value of the line or curve.
« Reply #6 on: May 24, 2012, 09:21:26 AM »
I've been seeing this a lot too. Perhaps the reason I can't 'create a Point'?
« Reply #7 on: May 24, 2012, 11:35:02 AM »
Are you running s administrator?
« Reply #8 on: May 24, 2012, 11:36:53 AM »
If you're referring to the OS yes I am. I'm still on XP.
« Reply #9 on: May 24, 2012, 11:49:47 AM »
sounds like you may want a repair install
« Reply #10 on: May 24, 2012, 12:00:28 PM »
I see the same behavior as Mark. In 2012 the point retains it's Z value when grip edited. In 2013 it takes on the elevation of the object snapped to.
« Reply #11 on: May 24, 2012, 12:32:12 PM »
thanks for the conformation Jeff. I knew I wasn't going crazy! :)
« Reply #12 on: May 24, 2012, 12:33:12 PM »
I was thinking the same thing.
« Reply #13 on: May 24, 2012, 12:54:54 PM »
Could someone post this on the Adesk news groups please. I would really like to know how to change this behavior.
thanks
« Reply #14 on: May 24, 2012, 01:09:19 PM »
I just posted a question about this, Mark. During my testing I encountered the same fatal error you mention above. I sent in the CER and within minutes I had an email from Tech support asking about it. I sent back the exact steps I had just gone through, and mentioned WHY I was doing the test (the change in workflow between 2012 & 2103 point grip editing). So I know it's in their system now.
