I have an Image in which each pixel is stored in a list of lists (of size m x n) as follows :-
(setq imagelist (list
(list 34 4 4 32 5 34 54 345 .....)
I am displaying this image on a DCL box. Problem is that my DCL box size is sometimes lesser than the size of list (m or n or both).
Is there any way by which I can eliminate every alternate 1, or 2, or 3, or more (dynamic) pixels as per the image size and as per DCL box size.
In a nutshell, I want to reduce the list of lists of size m x n to a x b where,
(i) a < m
(ii) b < n
(iii) m, n, a and b are known
(iv) Depending upon the ratio of a and m, the alternate 1, 2, or 3, or more pixels must be removed.
(v) Depending upon the ratio of b and n, the alternate 1, 2, or 3, or more lists must be removed.
I am ready to reduce the resolution or little bit distort the image wherever the pixels are removed.
