(defun c:p45 () (/ a1 a pt1 pt0 pbg ang1 len ed)
;; http://forums.augi.com/showthread.php?91585-Draw-a-line-starting-from-the-midpoint-of-itself
(princ
"\n Re+Place Object\(s\) with 1.0\" Line at Angle of Choice.."
) ;_ end of princ
(setvar "cmdecho" 0)
(setq A1 (if A1
A1
(/ pi 4)
) ;_ end of if
(if (setq ang1 (getangle "\n Enter/Pick Angle to Use: <"
; acquire angle
(angtos A1)
) ;_ end of getangle
) ;_ end of setq
(setq A1 (angtof ang1))
) ;_ end of if
) ; (if ;check for angle other than nil
; (= ang1 nil) ; if angle not nil..
; (setq ang (angtof "45")) ; use 45° if Enter is pressed
; (setq ang ang1) ; else use entered # >>
; ) ; end if
(while
(setq pt1 (getpoint "\nPick Basepoint of Object(s) to Replace: "))
; 'points' are picked
(setq len 0.5) ;setq half-length
(setq pt0 (polar pt1 ang1 len)) ;Calculate other endpoint
(setq pt1 (polar pt1 ang1 (* -2 len))) ; move location/base to place at mid/pick
(setq ed (list '(0 . "LINE") ; make line
(cons 10 pt0)
(cons 11 (polar pt1 ang1 len))
) ;_ end of list
) ;_ end of setq
(entmake ed) ;insert the line
) ;_ end of while
(princ " Erase Anything?")
(vl-cmdf "erase" pause)
(setvar "cmdecho" 1)
) ;_ end of defun
;) ;_ end of defun
;|«Visual LISP© Format Options»
(72 2 50 2 T "end of " 60 9 0 1 0 nil T nil T)
;*** DO NOT add text below the comment! ***|;
(defun c:p45 ( / ang1 pt1 pt0 len ed)
(setvar 'cmdecho 0)
(princ "\n Re+Place Object\(s\) with 1.0\" Line at Angle of Choice..")
(if (= *PA-1 nil)(setq *PA-1 (/ pi 4.0))) ;; initial var fill if nil..
(if (setq ang1 (getangle (strcat "\n Enter/Pick Angle to Use: <"(angtos *PA-1)"> "))) ;; acquire angle (angtos A1) " >"
*PA-1 (setq ang1 *PA-1) )
(while
(setq pt1 (getpoint "\nPick Basepoint of Object(s) to Replace: ")) ; 'points' are picked
(cons 10 pt1)
(cons 11 (polar pt0 ang1 len)) ; changed to put start-point at left
) ;_ end of list
) ;_ end of setq
) ;_ end of while
(setq *PA-1 ang1) ;; last change to save angle for repeat
;; hope that global is safe
(setvar 'cmdecho 1)
) ;_ end of defun
