Here'a a good one foy you all, is there a way of adding a dot, a point or a mark of some description that has the Y and Y coordinates attached?
Ideally I'm wanting is to add a number of dots, or marks to a drawing and the coordinates show up in a table at the side. If you moved the marks on the drawing then the coordinates would update automatically. Does anyone know if this can be done at all?
