Here are some chunks of our menu. I created it a long time ago, so if I were to do it again, I'd likely do it a little differently. This works though.
***MENUGROUP=TerraACAD
***POP1
**[&Terra Blocks]
//[&Borders...]^c^c$I=TerraACAD.image_BORDERS $I=*
[&Controllers...]^c^c$I=TerraACAD.image_CONTROLLERS $I=*
[&Electrical...]^c^c$I=TerraACAD.image_ELEC $I=*
[&Instrument Bubbles...]^c^c$I=TerraACAD.image_Bubbles $I=*
***IMAGE
**IMAGE_CONTROLLERS
[TERRA - Controllers...]
[TERRA(12,12)]^C^C-INSERT O:/DRAWINGS/Menus-Blocks/CONTROLLERS/12 \DRAG ;;;
[TERRA(14,14)]^C^C-INSERT O:/DRAWINGS/Menus-Blocks/CONTROLLERS/14 \DRAG ;;;
[TERRA(16,16)]^C^C-INSERT O:/DRAWINGS/Menus-Blocks/CONTROLLERS/16 \DRAG ;;;
What I did was to first create a script file to create the slides...
open C:\directory\drawing.dwg zoom e mslide close
open C:\directory\drawin2.dwg zoom e mslide close
etc...
Once the slides are created, you need to make sure that slidelib.exe is in C:\directory (the directory your slides are in)
As seen in the AutoCAD help file, go to dos prompt, and while in the directory, type:
dir *.sld /b > slidelist
Then, with that list in the same directory, type:
slidelib libraryname < slidelist
You then need to put 'libraryname.slb' in your AutoCAD Support directory and add the definition to your menu.
Being an advanced user, I probably don't need to go into a whole lot of detail, but if you need any more help, by all means, let me know.
Hope that helps!
Mike
