Code Red => AutoLISP (Vanilla / Visual) => Topic started by: myloveflyer on August 12, 2019, 11:30:04 PM
;;;by roy_043
(defun KGA_Conv_Pickset_To_ObjectList (ss / i ret)
(if ss
(setq ret (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) ret))
(defun c:Test ( / cen cirLst doc linLst radNew radOld ss)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vla-endundomark doc)
(vla-startundomark doc)
(and
(setq ss (ssget '((0 . "LINE,CIRCLE"))))
(setq radNew (getreal "\nNew radius: "))
(foreach obj (KGA_Conv_Pickset_To_ObjectList ss)
(if (= "AcDbLine" (vla-get-objectname obj))
(setq linLst
(vl-list*
(list (vlax-get obj 'startpoint) T obj)
(list (vlax-get obj 'endpoint) nil obj)
linLst
(setq cirLst (cons obj cirLst))
(foreach cir cirLst
(setq cen (vlax-get cir 'center))
(setq radOld (vla-get-radius cir))
(vla-put-radius cir radNew)
(foreach sub linLst
(if (equal radOld (distance cen (car sub)) 1e-8)
(vlax-put
(caddr sub)
(if (cadr sub) 'startpoint 'endpoint)
(vlax-curve-getclosestpointto cir (car sub))
(setq linLst (vl-remove sub linLst))
This app was written by a friend of the forum. The program now has a problem by changing the diameter of the circle to lengthen or shorten the length of the line between the circles. It is not dealing with slashes. I am not familiar with the VLAX feature. Which friend can help me solve this problem? thank you for your help!
There are significant inaccuracies in the drawing. Change 1e-8 to 1e-2.
(Tpst_Software_UseLimit)
It seems you are selling the code that was donated to you. Food for thought...
Original topic:
https://www.theswamp.org/index.php?topic=55199.0
Original topic:
Thanks,Roy!
This precision is to control the diameter of the circle. Is the accuracy in the drawing too low?
(Tpst_Software_UseLimit) This is the instructions for other users to run this program. :2funny:
No. The tolerance is used to determine if line points lie on the circle.
Certainly too low for a CAD drawing.
Please start a new topic for your other problem.
OK,Roy!
I will open another title.
This drawing is out of other calculation software, so the drawing of different calculation software may not be the same as the precision control. I will pay attention to this later. Thank you Roy, you have helped me a lot!
