Author Topic: Arc direction?  (Read 5589 times)
LE
Re: Arc direction?
« Reply #15 on: May 30, 2006, 09:01:55 PM »
Thanks, I noticed that let me see if I can fix it.
Re: Arc direction?
« Reply #16 on: May 30, 2006, 09:20:01 PM »
Alan, the only time I can get the result you do is when my point of selection of the tangent is on the 'downhill' side of the line from the perpendicular point, which is how I thought it would work......
FWIW, here is the original pic that the OP posted of what they are trying to do.
Re: Arc direction?
« Reply #17 on: May 30, 2006, 09:22:26 PM »
Jeff, I get that result no matter where I select on the line. Very curious?
LE
Re: Arc direction?
« Reply #18 on: May 30, 2006, 09:26:24 PM »
on the mean time, here are some formulas I did for one of my routines:
Arc angle
double arcAngle = ( 2.0 * atan( chord / 2.0 / sqrt(( pow(r,2) - pow(( chord / 2.0 ),2) ))) );
Arc length
#define PI 3.141592653589793238462643383279502884197169399375105820974944592308
#define PI360 6.283185307179586476925286766559
double arcLength = ((( ( arcAngle * 180.0 ) / PI ) / 360.0 ) * PI360 * r );
I do not have them as a lisp  :-(
pow() is the same as expt function in lisp
Re: Arc direction?
« Reply #19 on: May 30, 2006, 09:38:02 PM »
Jeff, i would have expected these results, no?
LE
Re: Arc direction?
« Reply #20 on: May 30, 2006, 09:43:25 PM »
Jeff & Luis,
What happens when you use the following example with the routine Luis provided?
PS line is 25 or so units long.
Now I did the test and is running just fine.
