Author Topic: Need Help on LISP that extracts X,Y,Z info from a 3Dpoly  (Read 5340 times)
grdruck
« on: March 10, 2005, 02:53:02 PM »
Hi all - I wrote some code to do the following:
here is my logic:
User Selects objects to export X,Y,Z data
Loop through each entity selected - no more entities exit program
Check if entity is a line, polyline, or 3Dployline
if not continue loop
if yes extract X,Y,Z info to external file
the Code I have so far:
;;   ExtXYZ_v2.LSP
;; Written by Garth Druckenmiller on March 10, 2005
;;       Updated on  -
;;     with help from various sources.   Thanks to those on TheSwamp.org
(defun C:EXTXYZ ()
  (Prompt "\nExtXYZ - Extracts X,Y,Z data from selected 3Dpolyline(s)")
  (Prompt "\n")
  (setq USEROS (getvar "osmode"))
  (setvar "osmode" 0)
  (setq OLD_CMDECHO (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (setq SELECTION_SET (ssget))
  (setq NO_OF_ITEMS (sslength SELECTION_SET))
  (setq SSPOSITION 0)
  (repeat NO_OF_ITEMS
     (setq ENTITY_NAME (ssname SELECTION_SET SSPOSITION))  ;; retrieve entity name
     (setq ENTITY_LIST (entget ENTITY_NAME))               ;; retrieve info about entity
     (setq ENTITY_TYPE (cdr (assoc 0 ENTITY_LIST)))        ;; retrieve entity type
     (cond ((equal ENTITY_TYPE "LINE")
               (prompt "\n Its a LINE")
           ((equal ENTITY_TYPE "LWPOLYLINE")
               (prompt "\nIts a POLYLINE")
;; when selected entity is a 3D polyline... do the following...
           ((equal ENTITY_TYPE "POLYLINE")
               (prompt "\nIts a 3DPOLYLINE")
      ;;(setq e (entget (car (entsel))))
      ;get the parent entity list
      (setq r 1)
      ;set loop control number to 1
      (while r
      ;while loop control is not nil, carry on looping
         (setq ENTITY_LIST (entget (entnext (cdr (car ENTITY_LIST)))))
         ;get the vertex entity list
         (if (/= (cdr (assoc 0 ENTITY_LIST)) "SEQEND")
         ;if it is not "end-of-sequence
       ;do the following
         (terpri)
         ;new line
         (princ (cdr (assoc 10 ENTITY_LIST)))
         ;print the co-ordinates
       );progn
               (setq r nil)
       ;if end of sequence, stop looping
         );if
        );while
     (setq SSPOSITION (1+ SSPOSITION))
    (setvar "CMDECHO" OLD_CMDECHO)
    (setvar "osmode" USEROS)
    (prompt "\nProgram complete.")
OK,  I don't have the part where it writes to an external txt file.
It runs ok and extracts info only for 3Dpolyline for now but I'm getting a *Cancel* at end of list of vertex's.  Please comment on code and if there is something really wrong.  I'm very new to LISP programing so please go easy on me.  Thx.
whdjr
Re: Need Help on LISP that extracts X,Y,Z info from a 3Dpoly
« Reply #1 on: March 10, 2005, 03:25:21 PM »
Change this
to
(setq SELECTION_SET (ssget '((0 . "POLYLINE"))))
then you don't need this:
or the paren after );while
I did not test this any more than what I commented on.  A good rule is to use local variables.  You have set up globals and that may be your problem. :)
« Reply #2 on: March 10, 2005, 05:53:15 PM »
Give this a try.
See if you can comment each line of code to figure out what is taking place.
;;   CAB  03/08/2005
;;  Write vertex points of 3d pline to text file
(defun c:3dpolyout (/ ss i ename vlst ent fn coords)
  (setq fn "3d Pline Points.txt")
  (prompt "\nSelect 3D polylines to export.")
  ;; select only 3D plines
  (setq ss (ssget '((0 . "POLYLINE") (-4 . "&") (70 . 8))))
  (if (and (and ss (> (sslength ss) 0))
  (setq fn (open fn "w"))
      (princ "***  Point list  ***" fn)
(setq ent (ssname ss (setq i (1- i))))
(print ent fn)
(while (and (setq ent (entnext ent))
   (setq vlst (entget ent))
   (= (cdr (assoc 0 vlst)) "VERTEX")
 (setq coords (cons (cdr (assoc 10 vlst)) coords))
(foreach x coords
 (print x fn)
      (print fn)
      (close fn)
(prompt "\n***  Lisp 3d Poly Out loaded, Enter 3dpolyout to run.")
« Reply #3 on: March 10, 2005, 06:14:32 PM »
Here's a slightly dofferent way of obtaining the coordinates at each vertex.
(defun poly-coords (poly / end param)
  (setq end (vlax-curve-getendparam poly)
param -1)
  (while (<= (setq param (1+ param)) end)
    (print (vlax-curve-getpointatparam poly param))
;;;*****EXAMPLE USE******
(defun c:prntpoly (/ poly)
  (and (setq poly (car (entsel)))
       (poly-coords poly)
« Reply #4 on: March 10, 2005, 06:25:57 PM »
Neat, Thanks Jeff. :)
« Reply #5 on: March 10, 2005, 07:25:22 PM »
I should point out that this method works with Oldstyle "heavy" polylines, LWpolylines and 3dpolylines.
grdruck
« Reply #6 on: March 22, 2005, 12:04:46 PM »
Thanks for your help guys - some of it is still over my head while other stuff I can understand. - grdruck
