Author Topic: New to Multiple Viewport - Display Question  (Read 6194 times)
craigr
Re: New to Multiple Viewport - Display Question
« Reply #15 on: January 13, 2014, 10:26:48 AM »
You Folks are sooooo far over my head!!
If I ever get remotely close to getting caught up, I really need to explore & learn 'Annotative'.
I watched a video on it on YouTube and it really looks neat. I just don't have the time to learn it well enough to use it regularly.
craigr
dgorsman
« Reply #16 on: January 14, 2014, 01:48:09 PM »
Having not had to deal with annotative scales much I'd have to defer to your experience. Would you mind posting a drawing with an example ?
Set up as per my earlier example.  In the layout are four viewports, each with a specific annotation scale assigned to them.  Only objects which have that annotation scale assigned will be shown in that viewport.  The fourth viewport is assigned the 1:30 scale, which I've added to all the annotative objects.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
tedg
« Reply #17 on: January 14, 2014, 02:09:32 PM »
Another option of freezing a layer per viewport, you can simply activate the viewport and use the _layfrz command or tool.
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
« Reply #18 on: January 14, 2014, 07:10:09 PM »
Am I missing something also but isn't that what annotative objects are for?
The problem I see most people have is ANNOAUTOSCALE & ANNOALLVISIBLE settings cause them confusion until they understand it.
Different  annotative scales will show at same size if you just attach one scale will not show not show up in any other scale.
Rob...
« Reply #19 on: January 14, 2014, 07:21:33 PM »
My understanding is that annotative scaling was added so that objects can print the same size regardless of scale. It is a major improvement on the (pardon my french) old school way of doing it with multiple objects on multiple layers. If there is a change to something that needs to be seen at multiple scales, only one edit is needed. The user also has the added advantage of being able to assign a specific list of scales to an object gaining the ability to limit which scales an object prints at.
CAD Tech
dgorsman
« Reply #20 on: January 14, 2014, 07:26:49 PM »
Automatically adding all scales to all objects certainly causes confusion, in that it creates the impression that all annotative objects will *always* be seen at all scales.  Even worse if you stick to the OOTB list of scales.
ANNOALLVISIBLE can actually be helpful during the learning process, since it won't actually hide objects they aren't "out of sight, out of my mind".
try {GreatPower;}
      {MasterBasics;}
« Reply #21 on: January 15, 2014, 08:23:56 AM »
Thanks for the example. That is a cool way to control what's visible.  8)
craigr
« Reply #22 on: January 15, 2014, 08:46:43 AM »
This is all so far over my head, but I am VERY Surprised that I am following what you folks are talking about! - I sounds VERY Cool, but I still don't know how to do it, YET.
I am anxious to learn it, but as I said above, I am VERY far behind in work, so I don't have the time to play with it and to learn it. From what I do understand of what you are describing, I just don't see that we would use it that often. MAYBE, once or twice a year. So, I probably wouldn't remember it well enough to be productive with it anyway.
That being said, it sounds like something that would be a blast to play with.
This has definitely been one of the more interesting topics I have read lately. THANKS
craigr
dgorsman
« Reply #23 on: January 15, 2014, 10:01:57 AM »
We don't use it much either.  Most of our work is either 3D and annotated in paper space, or 2D schematic and not needing annotation scales.  We used to get a lot of maps for pipeline work, and they were making full use of annotative objects.  Most of the 2D mapping work has been offloaded to geomatics-type programs which are now better suited to the work.
There is one area where I kinda-sorta use it.  In our models the linetypes can be too small to clearly see, so I usually put in a 1:30 scale in and make that current.  Makes pipe and steel center lines clearly visible without dorking around with the LTSCALE values.
try {GreatPower;}
      {MasterBasics;}
Rob...
« Reply #24 on: January 15, 2014, 02:46:35 PM »
Actually, I don't have a need to use it very often but I use it all the time nonetheless for those times when I do need it's functionality.
CAD Tech
Bethrine
« Reply #25 on: January 16, 2014, 02:35:49 PM »
Maybe I should really put more effort into learning it seeing as I work on mechanical parts drawings....?  :evil: :ugly:
Rob...
« Reply #26 on: January 16, 2014, 02:40:44 PM »
It can be a bit daunting at first as there are a few variables to learn but once you "get it", you're in like flint and probably wonder how you lived without it.
CAD Tech
