I have been using Viewports for quite a few years, but now want to add 2 extra Viewports to the same dwg. So, I have run into an issue that hopefully has a simple solution.
I put all of my 'labels' on one layer that I call Dims. These always are in a QLeader with a box around it and the Arrow pointing at the device. But, now that I am adding 2 extra Viewports, these 2 extra Viewports will have different 'zoom' scales, which throws off the scale of my text - which I have set to automatically scale to the Viewport.
What I would like to happen is for the Dims in Viewport1 to only appear in Viewport1 and NOT in the other 2 Viewports. Viewports 1 & 2 are simply zoomed in areas of the overall building which is shown in Viewport3.
I'm guessing that I could simply make layers 'Dims1', 'Dims2' & 'Dims3' then have them only show up in the appropriate Viewports, but is there another or more appropriate way of doing this?
I hope I have explained this so that you understand what I am after.
craigr
