Author Topic: Need Help Converting Esri gdb to shp  (Read 11538 times)
dfarris75
« on: December 01, 2010, 02:17:40 PM »
I have dtm data in a Esri geodatabase that I need converted to a usable format (shp, dxf, etc.). Is anyone willing and able?
Re: Need Help Converting Esri gdb to shp
« Reply #1 on: December 01, 2010, 02:39:00 PM »
I don't have any experience (or at least I don't think I do) with a geodatabase, but I have had some real-time OJT for the shp format.
I can tell you that the ESRI shp format is very well documented and should be a fairly straightforward task to convert the files.
CHulse
« Reply #2 on: December 01, 2010, 02:53:01 PM »
Can do :)
I'll email you...
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
dfarris75
« Reply #3 on: December 01, 2010, 03:04:03 PM »
You rock!
Scott
« Reply #4 on: December 01, 2010, 03:33:28 PM »
If this is something you need to do often, you might consider looking into Global Mapper.  For the money it is well worth it for file conversions as well as a whole host of other things.
« Reply #5 on: December 01, 2010, 05:58:40 PM »
late to the table on this one...what is the FILE format?  IF shp file you should be able to use MAP>>Import>>>SHP file
IF other...directions to follow
dfarris75
« Reply #6 on: December 02, 2010, 11:06:02 AM »
no the original data was not shp or i wouldn't have needed to post. cary converted it for me, but for some reason the contours come in at 0 elevation although the elevation is attached as data. would i be able to move those contours to their proper z via a query or other method? something more satisfying than a manual operation is desired.
dfarris75
« Reply #7 on: December 02, 2010, 11:09:17 AM »
nevermind i got it done via query. thx!
CHulse
« Reply #8 on: December 02, 2010, 11:40:10 AM »
The original data was an ESRI "File GeoDatabase" format. I used ESRI ArcGIS to convert to shape.
Darcy - can you explain the process you used to get the correct elevations?
Cary Hulse
dfarris75
« Reply #9 on: December 02, 2010, 12:25:59 PM »
Absolutely.
I created a new blank dwg file from my company template
I attached the dwg that contained the contours (@ 0 el.) via Map
I defined the query with a Location of ALL with the Property set to Layer and selected the contours layer (DEM-LiDAR Contours in this case)
Set the Query Mode to DRAW
Clicked Alter Properties
Select Property > Elevation
Clicked Expression
Expanded Object Data (because the data was attached to the contours)
Selected CONTOUR_EL and clicked OK
Clicked ADD under Expression and clicked OK
Execute Query
and YEEEEEEEHAWWW! there are the contours at their proper Z value!
« Reply #10 on: December 02, 2010, 10:56:59 PM »
Absolutely.
Clicked Expression
Execute Query
Just like I taught you how.  Good Job!   ;-)
CHulse
« Reply #11 on: December 03, 2010, 07:40:15 AM »
That's great - I didn't know you could do that :)
Cary Hulse
dfarris75
« Reply #12 on: December 03, 2010, 10:19:28 AM »
Yes indeedy. If not for Mike I wouldn't know that trick! :love:
reno
« Reply #13 on: December 04, 2010, 12:04:18 PM »
if i remember correctly, the map subscription thingy had something for geodatabases. not positive about that though
« Reply #14 on: December 04, 2010, 12:13:32 PM »
just asking....
given the user is operating the 2008 version; what do you think the chances are they are on subscription?
given that it can be done without any 'extension' why would anyone chose that option?
is it faster or easier or more feature rich?
