Open explorer windows can be discovered and programmed by using IShellWindows (CLSID_ShellWindows)...
Lee Mac and MickD,This has been bugging me for years as well! I may have found the solution today ( works on my computer Win 11, Version 10.0.22631 Build 22631) A simple mod from 'explore to 'open.
Thanks for the suggestions. I found something that may help, though it is a bit dated (refers to IE): https://learn.microsoft.com/en-us/windows/win32/shell/developing-with-windows-explorerQuoteOpen explorer windows can be discovered and programmed by using IShellWindows (CLSID_ShellWindows)...
I think using WSH to access this I'll be able to do what I want.
I'll post back what I find.
This has been bugging me for years as well! I may have found the solution today ( works on my computer Win 11, Version 10.0.22631 Build 22631) A simple mod from 'explore to 'open.Code - Auto/Visual Lisp: [Select]
) ;; ;; RJP » 2024-02-14 ;; Using 'open vs 'explore will not open multiple windows with the same path ) ) ) )
Cheers!QuoteThis has been bugging me for years as well! I may have found the solution today ( works on my computer Win 11, Version 10.0.22631 Build 22631) A simple mod from 'explore to 'open.Code - Auto/Visual Lisp: [Select]
That is exactly the behavior I wanted! Thanks! Now I need to dig through some of my older code and switch to this.
