Code Red => AutoLISP (Vanilla / Visual) => XDRX-API => Topic started by: xdcad on December 10, 2023, 02:22:13 PM
Title:
[XDrX-Function(23)] Quickly build triangulation Network
Post by:
xdcad
on
Code - Auto/Visual Lisp:
[Select]
Command
: TT
Select Points
Exit
Specify opposite corner:
46320
found
Select Points
Exit
Collection point...
Points collected:
46320
, time taken:
0.00
seconds.
Generate triangulation...
Generation of triangulation network completed, time taken:
5.69
seconds.
Command
FUNCTION:
(xdrx_points_Delaunay pts [t])
Parameter T, draw directly, otherwise return to point list
[Select]
defun
c:tt
if
setq
ss
xdrx
ssget
\n
Select Points<Exit>"
0
"point"
progn
xdrx
runtime t
xdrx
prompt
\n
Collection point..."
setq
pts
xdrx
getpropertyvalue ss
"position"
pts
apply
append
pts
setq
ti
xdrx
runtime
xdrx
prompt
xdrx
string
format
\n
Points collected: %d, time taken: %.2f seconds."
length
pts
ti
xdrx
prompt
\n
Generate triangulation..."
xdrx
runtime t
xdrx_points_Delaunay pts t
setq
ti
xdrx
runtime
xdrx
prompt
xdrx
string
format
\n
Generation of triangulation network completed, time taken: %.2f seconds."
ti
princ
