here's my startup process, what a mess huh?
Loading AecBase...
Loading AecUiBase...
Loading AecArchBase...
Loading AecUtilities...
Loading AecArchX...
Loading AecScheduleData...
Loading AecScheduleDataArch...
Loading AecUiScheduleData...
Loading AecArchXM...
Loading AecDCArch...
Loading AecStructureBase...
Loading AecStructure...
Loading AecSchedule...
Loading AecUiSchedule...
Loading AecAreaCalculationBase...
Loading AecArchDACHBase...
Loading AecAreaCalculation...
Loading AecArchDACH...Substituting [arial] for [dim].
Substituting [arial] for [Univers].
Regenerating model.
DOSLib Version 5.1.1 (Jul 24 2000)
Copyright © 1992-2000, Robert McNeel & Associates
Initializing VBA System...AcadStatButton by ManuSoft.
http://www.manusoft.comLtscale_Switch loaded by CAD-Novation.
http://www.cadnovation.com.
Copyright © 2000-2001 CAD-Novation.
Plot Tabs is loaded, Enter PLotTabs to run.
Command:
Command:
Command:
Command:
Command:
Type BAP to run.....
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
Command:
DDBrep v2.0 loaded
Command:
Dimarc - Version 2.0 Copyright 2002 by BCI Computer Solutions
Command:
Command:
Command:
Command:
Command: DLINE loaded.
Command:
Command:
Yellow
Double Break Symbol Creator loaded. Type DZ to run it.
Yellow
Yellow
Yellow
Yellow
Yellow
Insert where?
Command: *Cancel*
; error: Function cancelled
Yellow
Yellow
Leader/Text Mover Loaded, Type LM to run
Yellow
Yellow
Yellow
Yellow
Yellow
Type MB to Run
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
-- Attribute Modification Utility Ver 4.0 -- start command with --> MODATT
-- Copyright (C) 1999-2003 by BCI Computer Solutions
Yellow
Yellow
Move_Lay - Move All Entities on a Layer To A Different Layer. Type MLA to
begin.
Yellow
-------------------> Use O2L to run Offset2Layer
Yellow
Yellow
Yellow Loading PL2Cloud....
Enter PL2Cloud to run.
Yellow
Yellow
Enter psText to add text.
Enter psText-edit to edit text.
Yellow
Yellow
Yellow
Yellow
*-* Rename Tab layouts Loaded, Enter rnl to run. *-*
Yellow
Yellow
Yellow
Yellow
Yellow
Yellow
Text / Dimension Style Changer Loaded, Type TDS to run
Yellow
Text Increment Loaded, Enter TxtInc to run.
Yellow
Yellow
Yellow
Yellow
*-* Viewport Lock/Unlock Loaded. Enter vptog to run. *-*
Yellow
Yellow
Yellow
Yellow
Yellow
AutoCAD Express Tools Copyright © 2000 Autodesk, Inc.
_.menuunload
Enter the name of a MENUGROUP to unload:PartsNowPD
Menu unloaded successfully. MENUGROUP: PartsNowPD
Command:
Command: _.menuunload
Enter the name of a MENUGROUP to unload:PartsNowTB
Menu unloaded successfully. MENUGROUP: PartsNowTB
Command:
Command: _.menuload
Enter name of menu file to load: C:/PROGRAM FILES/PARTSNOW/PartsNowTB.mnu
Menu loaded successfully. MENUGROUP: PartsNowTB
Command:
Command: _.-toolbar Enter toolbar name or [ALL]: PartsNow
Enter an option [Show/Hide/Left/Right/Top/Bottom/Float] <Show>: _show
Command:
Command: _.menuload
FILES/PARTSNOW/USR/DP_LIB/PartsNowPD.mnu
Menu loaded successfully. MENUGROUP: PartsNowPD
Command:
Command: -layer
Current layer: "4-SYMBOLS"
Enter an option
[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]:
ON
Enter name list of layer(s) to turn on: z-barcode Enter an option
Thaw
Enter name list of layer(s) to thaw: z-barcode Enter an option
P
Enter a plotting preference [Plot/No plot] <Plot>: N
Enter layer name(s) for this plot preference <4-SYMBOLS>: z-barcode Enter an
option
AutoCAD menu utilities loaded.
CCOUNT.LSP not found
CR.LSP not found DLINE loaded.
EO.LSP not found
EPU.LSP not found
FU.LSP not found
ISOBLK.LSP not found
LSB.LSP not found
Type MB to Run
MET.LSP not found
MF.LSP not found
MML.LSP not found
MR.LSP not found
MULL.LSP not found
OO.LSP not found
PAGESETUPS.LSP not found
PANE14.LSP not found
PANE18.LSP not foundPlot Tabs is loaded, Enter PLotTabs to run.
PT.LSP not found
REFL.LSP not found
RWORD.LSP not found
STAIRS.LSP not found
ZT.LSP not found
Files Loaded.....
Dan is loaded.....Plot Tabs is loaded, Enter PLotTabs to run.
DDBrep v2.0 loaded
; error: LISP application is already loaded DimTextOverRide
DLINE loaded.
Insert where? *Cancel*
Type MB to Run
begin.
-------------------> Use O2L to run Offset2LayerLoading PL2Cloud....
*-* Viewport Lock/Unlock Loaded. Enter vptog to run. *-*Enter an option
*Cancel*
