Author Topic: Dim style question  (Read 2986 times)
rjohnson42
Dim style question
« on: October 18, 2011, 11:28:12 AM »
Fellas,
Here's a bit of code that I'm using to create a new dim style if it doesn't exist:
(defun c:tst()
;create text Style
(if (not (tblsearch "style" "ROMANS")) (command "-style" "ROMANS" "ROMANS.SHX" 1.25 1.0 0 "N" "N" "Y"))
;create dimension style
(if (not (tblsearch "DImstyle" "TIC 1_20"))
(command "dim" "style" "ROMANS"
"DIMALTD" 2
"DIMALTF" m
"DIMALTRND" 0
"DIMALTF" 25.4
"DIMALTTD" 2
"DIMALTTZ" 0
"DIMALTU" 2
"DIMALTMZF" 100
"DIMALTZ" 0
"DIMALT" 0
"DIMATFIT" 3
"DIMAUNIT" 0
"DIMAZIN" 0
"DIMARCSYM" 0
"DIMBLK" ""
"DIMBLK1" ""
"DIMBLK2" ""
"DIMASZ" 0.0625
"DIMLDRBLK" ""
"DIMCEN" 0.0313
"DIMCLRD" 256
"DIMCLRE" 256
"DIMCLRT" 256
"DIMDEC" 2
"DIMDSEP" "."
"DIMDLE" 0
"DIMDLI" 0.5
"DIMEXE" 0.0625
"DIMEXO" 0.0625
"DIMFRAC" 0
"DIMFXLON" 0
"DIMFXL" 1
"DIMGAP" 0.0313
"DIMJOGANG" 45
"DIMJUST" 0
"DIMLFAC" 1
"DIMLIM" 0
"DIMLTYPE" "BYLAYER"
"DIMLTEX1" "BYLAYER"
"DIMLTEX2" "BYLAYER"
"DIMLUNIT" 2
"DIMLWD" -2
"DIMLWE" -2
"DIMPOST" "'"
"DIMRND" 0
"DIMSAH" 0
"DIMSCALE" 20
"DIMSD1" 0
"DIMSD2" 0
"DIMSE1" 0
"DIMSE2" 0
"DIMSOXD" 0
"DIMTAD" 1
"DIMTDEC" 2
"DIMTXTDIRECTION" 0
"DIMTFAC" 0.25
"DIMTFILLCLR" 0
"DIMTFILL" 0
"DIMTXT" 0.0625
"DIMTIH" 1
"DIMTIX" 0
"DIMTM" 0
"DIMTMOVE" 0
"DIMTOFL" 0
"DIMTOLJ" 1
"DIMTOH" 1
"DIMTP" 0
"DIMTOL" 0
"DIMTZIN" 0
"DIMLIM" 0
"DIMMZS"
"DIMTXSTY" "ROMANS"
"DIMZIN" 3 /e)
) ;progn
      ) ;if
) ;defun
For whatever reason, ACAD returns "nil" when I run this and the style is not created.
I would appreciate any help/guidance,
Robert
Re: Dim style question
« Reply #1 on: October 18, 2011, 11:45:19 AM »
Two lines I see which may have problems:
"DIMALTF" m
"DIMZIN" 3 /e
The "nil" output can be suppressed by adding (princ) to the end of the code.
« Reply #2 on: October 18, 2011, 01:12:42 PM »
rjohnson42
« Reply #3 on: October 19, 2011, 08:10:29 AM »
"DIMALTF" m
"DIMZIN" 3 /e
You are correct - thanks!
Some info to consider.
http://www.theswamp.org/index.php?topic=1669.0
I attempted to use the code posted by nivuahc, but I'm getting an error regarding "too many arguments"... Here's what I have:
(defun c:tst()
;create text Style
(if (not (tblsearch "style" "ROMANS")) (command "-style" "ROMANS" "ROMANS.SHX" 1.25 1.0 0 "N" "N" "N"))
(if (not (tblsearch "Dimstyle" "TIC 1_20"))
(SETVAR "CMDECHO" 0)
;;Below are the dimstyle variables
(setvar "DIMADEC" 0)
(setvar "DIMALTD" 2)
(setvar "DIMALTF" 25.4)
(setvar "DIMALTRND" 0)
(setvar "DIMALTTD" 2)
(setvar "DIMALTTZ" 0)
(setvar "DIMALTU" 2)
(setvar "DIMALTZ" 0)
(setvar "DIMAPOST" "")
(setvar "DIMASSOC" 2)
(setvar "DIMASZ" 0.125)
(setvar "DIMATFIT" 3)
(setvar "DIMAUNIT" 0)
(setvar "DIMAZIN" 0)
(setvar "DIMCEN" 0.0781)
(setvar "DIMCLRD" 0)
(setvar "DIMCLRE" 0)
(setvar "DIMCLRT" 0)
(setvar "DIMDEC" 4)
(setvar "DIMDLE" 0)
(setvar "DIMDLI" 0.0938)
(setvar "DIMDSEP" ".")
(setvar "DIMEXE" 0.0469)
(setvar "DIMEXO" 0.0469)
(setvar "DIMFIT" 3)
(setvar "DIMFRAC" 2)
(setvar "DIMGAP" 0.0781)
(setvar "DIMJUST" 0)
(setvar "DIMBLK" ".")
(setvar "DIMBLK1" ".")
(setvar "DIMBLK2" ".")
(setvar "DIMLFAC" 1)
(setvar "DIMLUNIT" 4)
(setvar "DIMLWD" -2)
(setvar "DIMLWE" -2)
(setvar "DIMPOST" "")
(setvar "DIMRND" 0)
(setvar "DIMSCALE" 20)
(setvar "DIMTAD" 0)
(setvar "DIMTDEC" 4)
(setvar "DIMTFAC" 1)
(setvar "DIMTM" 0)
(setvar "DIMTMOVE" 0)
(setvar "DIMTOLJ" 1)
(setvar "DIMTP" 0)
(setvar "DIMTSZ" 0)
(setvar "DIMTVP" 0)
(setvar "DIMTXSTY" "ROMANS")
(setvar "DIMTXT" 0.0781)
(setvar "DIMTZIN" 0)
(setvar "DIMUNIT" 6)
(setvar "DIMZIN" 0)
(setvar "DIMLDRBLK" "")
(command "-dimstyle" "s" "TIC 1_20")
      ) ;if
) ;defun
« Reply #4 on: October 19, 2011, 08:21:01 AM »
The IF function only requires 2 (optionally 3) arguments.
You have supplied it with 56 arguments.
Use the 'progn' function to pass the 'setvar' statements to the IF function as one argument.
rjohnson42
« Reply #5 on: October 19, 2011, 11:17:38 AM »
Just to let everyone know, I figured it out with the help of Mac.
Here's what I ended up with:
(defun Styles( )
    (if (not (tblsearch "STYLE" "ROMANS"))
        (command "_.-style" "ROMANS" "ROMANS.SHX" 1.25 1.0 0 "_N" "_N" "_N")
    (if (not (tblsearch "DIMSTYLE" "TIC 1_20"))
            (setvar "CMDECHO" 0)
            (setvar "DIMAPOST" "m")
            (setvar "DIMASZ" 0.0625)
            (setvar "DIMCEN" 0.0313)
            (setvar "DIMCLRD" 256)
            (setvar "DIMCLRE" 256)
            (setvar "DIMCLRT" 256)
            (setvar "DIMDEC" 2)
            (setvar "DIMDLE" 0)
            (setvar "DIMDLI" 0.5)
            (setvar "DIMEXE" 0.0625)
            (setvar "DIMEXO" 0.0625)
            (setvar "DIMFIT" 3)
            (setvar "DIMFRAC" 0)
            (setvar "DIMGAP" 0.0313)
            (setvar "DIMLUNIT" 2)
            (setvar "DIMPOST" "'")
            (setvar "DIMRND" 0)
            (setvar "DIMTAD" 1)
            (setvar "DIMTDEC" 2)
            (setvar "DIMTFAC" 0.25)
            (setvar "DIMTM" 0)
            (setvar "DIMTP" 0)
            (setvar "DIMTSZ" 0)
            (setvar "DIMTVP" 0)
            (setvar "DIMTXT" 0.0625)
            (setvar "DIMZIN" 3)
            (setvar "DIMLDRBLK" ".")
            (command "_.-dimstyle" "_s" "TIC 1_20")
        );end progn
    );end if
);end defun
Thanks again to Mac and the others. I've got my pet project of the week done.   :mrgreen:
