Code Red => .NET => Topic started by: gablackburn on January 20, 2012, 11:54:47 AM
I'd like to get a Point3DCollection of all the endpoints of lines in a particular layer but I haven't found a way to do it.
I can figure out how to do it for blocks, but up until this point, I've never needed it for osnaps.
Dim myEndPtColl As New Point3dCollection
Dim myPointFilter(1) As DatabaseServices.TypedValue
myPointFilter(0) = New DatabaseServices.TypedValue(DatabaseServices.DxfCode.LayerName, "WALLS")
myPointFilter(1) = New DatabaseServices.TypedValue(DatabaseServices.DxfCode. ????? OSMODE 1 ?????)
Is this possible or am I going about this the wrong way?
Thanks in advance,
G.A. Blackburn
edit: PS - I'm using VB.NET
It looks like you're going the wrong way. You cannot select "EndPoints" only entities as lines.
So, select the lines, then iterate through the selection to get each line EndPoint.
Thanks for the response gile, sorry it took so long but I was out of town. Although I didn't post the code, I will be creating a selection set of all the lines in the WALLS layer. I'll see if I can cycle through to get the 3D coordinates of the endponts.
