That's simply a reminder that if you send the drawing to someone else and they say "I can't see <some feature or other>, it's missing from the drawing!", then you should ask them "Do you have PROXYSHOW set to 1?"
OK, so proxy info is mainly about spreadsheets and tables?
What kind of proxy graphic is so common that I might actually end up shafting some ACAD2000 user by altering my ADT2006 Open&Save default?
And should I just ignore the warnings? It sounds like this is a much less dangerous issue than it sounded initially... correct?
Thanks for all of the input you guys!
-SaMo2
