YES once a block is made; using the BLOCK command that block should be INSERTED always, and NEVER copied.the copy and paste as block function should always be avoided...and yes copying that pasted as block STILL bloats the file and creates yet more unnamed blocks...both BAD cad habits to engage in.As I am oft reminded; Just because you can, never means one should do anything.Yes one can copy, and paste as block...however it creates unnamed blocks which autocad really doesn't like much at all.
< .. >QuoteYes one can copy, and paste as block...however it creates unnamed blocks which autocad really doesn't like much at all.AutoCAD doesn't care if you use anonymous blocks, just grumpy old CAD people do
And anyone trying to extract from attributes from named blocks .... And anyone attempting to do a block count of named blocks.Copy is not an issue.Paste as block can be.
