Author Topic: Help - Dinamic block  (Read 4599 times)
Fabricio28
« on: January 21, 2013, 10:19:42 AM »
Hey Folks,
I have a dinamic block and I want  to add rotate parameter in it.
But I'm having trouble because I don't wanna rotate the texts inside the block, I just want to rotate the rectangle.
Can anyone help me, please?
« Last Edit: January 21, 2013, 10:51:35 AM by FABRICIO28 »
Fabricio28
Re: Help - Dinamic block
« Reply #1 on: January 21, 2013, 11:21:00 AM »
Sorry guys,
Moved for correct thread.
Dinamic Blocks.
 :pissed:
Nibster
« Reply #2 on: January 21, 2013, 11:52:45 AM »
What you want to do is associate your disks and text with a point parameter (which is in MOVE mode), one for each disk, then chain the two point parameters to the rotate parameter for the rectangle.  You don't associate the disks or the text to the rotate, you let the point parameter do that for you.  The disks will then act like ferris wheel cages.
Fabricio28
« Reply #3 on: January 21, 2013, 12:04:24 PM »
Thank for the quick replay Nibster,
Yes, I don't wanna associate the text to the rotate.
I don't Know how Can I do that.
Could you help me, please?
Regards
 :-D
Nibster
« Reply #4 on: January 21, 2013, 02:02:33 PM »
ok, here's the in-the-flesh version of the mumbo jumbo I typed above.  I also set the point parameter grip to "0" for that parameter's property so the point grip isn't used by accident
insert as a block, don't open.
Fabricio28
« Reply #5 on: January 21, 2013, 02:19:15 PM »
Perfect Nibster,
I was trying create a dinamic block, but no success so far.
Could you help me doing a block like mine, please?
you're helping me a lot, but I still have doubts.
Nibster
« Reply #6 on: January 21, 2013, 02:24:01 PM »
sure.  post what you have for your block, with 0,0 being the rotation base, and i'll walk you thru what I did to make it dynamic.  I don't think it will work well on the dimension part tho, if it is to be a part of the block.
Fabricio28
« Reply #7 on: January 21, 2013, 02:40:20 PM »
I just wanna my block rotate and the text inside not.
I really appreciate your help.
 :-D
Nibster
« Reply #8 on: January 21, 2013, 02:49:58 PM »
where do you want the rotation point?
Fabricio28
« Reply #9 on: January 21, 2013, 02:53:44 PM »
Could be anywhere my friend.
Nibster
« Reply #10 on: January 21, 2013, 02:57:02 PM »
never mind, you can change BP.
First I added all parameters only (no actions)
Then I double clicked each point parameter to start the object selection, picked "MOVE" option, then added the text and circle for each parameter.
Then select each point parameter and go over to properties dialog.  Change grip to 0, Chained: Yes, Show properties: No.
Double click the rotation parameter and then select the rectangle and then the point parameters ONLY.
Test. Done.
« Last Edit: January 22, 2013, 09:37:28 AM by Nibster »
Fabricio28
« Reply #11 on: January 21, 2013, 03:00:32 PM »
Nibster,
many Thanks!!
It's exactly what I was trying to do.
I have to go home now, and I'll take a look carefully in your block, tomorrow.
But I tested and worked like a charm!
regards
Fabricio28
« Reply #12 on: January 22, 2013, 05:47:36 AM »
How did you associate the elements inside the block to rotate?
Because I've tried to do a block like yours, but when I rotate the block, the elements inside the block didn't.
I'm doing something wrong.
Nibster
« Reply #13 on: January 22, 2013, 09:40:22 AM »
did you follow my directions i posted with the block?   a common mistake is associating too much geometry with the rotate.
If you click on the little action icons while in the Block Editor you can see what objects are associated with the actions.
Fabricio28
« Reply #14 on: January 22, 2013, 10:13:59 AM »
Yes, I did.
I forgot chain actions ON.
Many Thanks
