Author Topic: Function design (thoughts)  (Read 7131 times)
« Reply #15 on: March 30, 2005, 01:38:26 PM »
Quote from: MP
You kind of did, you're just following VB(A) naming conventions: IsArray, IsDate, IsEmpty ...
Maybe it's to much Python and C++ and PHP and PERL ...... *grin*
funny fact:
When I write something in C++ I compile it right from Vim using the builtin command "make". Well the other day I wrote a little autolisp routine and then ran "make" on it. "oop's that didn't work" :oops:
« Reply #16 on: March 30, 2005, 01:45:01 PM »
I hear ya -- can't tell you how many times I've been coding basic and typed "(defun ..."
« Reply #17 on: March 30, 2005, 01:48:13 PM »
As long as we are on the subject of args/vars:
If im actualy building true "suport procedures" like Marks "istext" example i usualy rely on scoping to handle my args/vars.
Forinstance:
(defun c:MyApp ( / ename textp)
  (while (not (setq ename (entsel "\nselect object: "))))
 ;; suport procedure
  (defun textp ( )
      (member
        (cdr (assoc 0 (entget (car ename))))
        '("TEXT" "MTEXT")
  (if (textp)
    (alert "Congrats! You selected some Text.")
    (alert "Nope!")
This makes it that much easier for me to read. (Look at my "if" vs this:
 (if (textp (car ename))
Using lexical scoping in your procedure design, i believe, is much easier to follow.
« Reply #18 on: March 30, 2005, 01:52:15 PM »
To each their own, but I wouldn't code it like that myself, though I am a proponent of lexical scoping.
« Reply #19 on: March 30, 2005, 01:55:51 PM »
Why?
« Reply #20 on: March 30, 2005, 01:57:23 PM »
Primarilly code clarity and re-use.
« Reply #21 on: March 30, 2005, 02:03:34 PM »
Re-use is the reason i use it.
Pulling that procedure out and trying to hack together an app is hard.  (Forces me to "Build" a procdeure and not "cut 'n paste" one.) I realise that my "worker procedures" could get a bit bloated this way (-ie. building built-in support procedures for each) but its worth the overall robust-ness i achieve.
« Reply #22 on: March 30, 2005, 02:11:33 PM »
Quote from: Mark Thomas
Quote from: Kerry Brown
The ugly side to this can be the 'indiscriminate wrapping' I see sometimes.
Sorry but I don't understand.  :oops:
I have seen [ read as,  debugged others code ] that has taken this concept a little to far. Its a different issue if the wrapped routine is used more than once or if it has a significant purpose.  ... sort of negates the 'readability' aspect. .. but admittedly that was for code that I didn't originate, so a reasonable amount of mental gymnastics is expected. :)
 .... on the other hand, a 3 page function that has no white space for thought delineation, and no header comments [ I prefer those to in line comments, the code should speak to me ] and everything inline and questionable variable naming regimen is a completely different can of worms.
« Reply #23 on: March 30, 2005, 02:19:21 PM »
... while [ sort of ] on the topic of debugging ..
I frequently will write a named routine just for testing, then include its code in line to reduce the necessity of passing variables to a helper.
