I believe I have not expressed myself correctly.
Display CAD model in true size 1:1 on your monitor.
Searching the internet I found what I needed, however it is a * .vlx file
I used a virtual machine to test the program and it really works.
It requests the size of your screen in inches and the scale.
https://www.cadforum.cz/cadforum_en/display-cad-model-in-true-size-1-1-on-your-monitor-tip8794Unfortunately I learned the worst way not to use compiled files when you have access to the internet without restrictions of access to FTP for example ...
Opening the .vlx file, we have a hint that two functions have been compiled and one of them is related to the internet I suppose.
LOAD((:protected . T) (:active-x . T) (:separate-namespace) (:load-file-list (:fas "webupdate") (:fas "view11")))
Unfortunately this routine I can not use.
But thanks for your answer, my friend.
